iiyama Prolite X4071UHSU-B1 40" 3ms HDMI DisplayPort VGA 4K LED Mon
Quicklinx: CB0DWS00 Mfr#: X4071UHSU-B1
The ProLite X4071UHSU-B1 is an impressive 4K (3840 x 2160) monitor, offering a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch) the monitor displays an incredibly sharp and crisp image. The VA panel technology offers exceptional color performance, high contrast (5000:1) and wide viewing angles. PIP and PBP features allow users to easily create their own work space by displaying and manipulating multiple applications. USB 3.0 HUB, integrated speakers, headphone socket and hook, ensure compatibility across various devices and media platforms for a real multimedia experience. The ProLite X4071UHSU-B1 suits a massive range of applications including desktop publishing, CAD/CAM drawing, gaming, photographic and web design.
  • 4K
    UHD resolution (3840 x 2160), better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image.
  • MVA
    MVA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
iiyama ProLite X4071UHSU-B1 - LED monitor - 40"
LED-backlit LCD monitor - 40"
Energy Class
Class B
Energy Consumption per Year
99 kWh
Power Consumption (On mode)
67.7 W
USB 3.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 60 Hz, HDMI2/MHL: 30 Hz, HDMI3: 30 Hz)
Pixel Pitch
0.229 mm
Brightness
350 cd/m²
Contrast Ratio
5000:1 / 12000000:1 (dynamic)
Response Time
3 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, HDMI (MHL), VGA, DisplayPort
Voltage
90.65 cm x 23.85 cm x 57.7 cm
12.2 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B, CU
Display Type
Energy Class
Class B
99 kWh
Diagonal Size
40"
Viewable Size
39.5"
Built-in Devices
USB 3.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.229 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
3 ms (grey-to-grey)
Vertical Refresh Rate
24 - 75 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, sharpness
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese
Picture in picture, picture by picture, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), X-Res Technology, blue light reduction, i-Style Color
90.65 cm x 23.85 cm x 57.7 cm - with stand
12.2 kg
Audio
Speakers - stereo
Output Power / Channel
6 Watt
VGA , MHL / HDMI , 2 x HDMI , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , Serial input , Audio line-out (mini-jack) , Headphones (mini-jack)
Mechanical
VESA Mounting Interface
400 x 200 mm
Remote control, 2 stands, 2 screws
1 x HDMI cable , 1 x audio cable , 1 x USB cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x DisplayPort cable , 1 x serial cable
Input Voltage
67.7 W
Power Consumption (Typical)
60 Watt
Power Consumption Stand by
0.5 Watt
Microsoft Windows 95/98/ME/2000/XP/Vista/7/8, Windows 10
Dimensions & Weight Details
With stand - width: 90.65 cm - depth: 23.85 cm - height: 57.7 cm - weight: 12.2 kg , Without stand - width: 90.65 cm - depth: 5.2 cm - height: 52.05 cm
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
