iiyama ProLite T1931SR-B5 19" 1280x1024 5ms HDMI VGA DisplayPort LED Monitor
Quicklinx: DKJGWS00 Mfr#: T1931SR-B5
Iiyama ProLite T1931SR-B5 19" touchscreen LED Monitor - 1280 x 1024 - TN - 250 cd/m² - 1000:1 - 5 ms - HDMI, VGA, DisplayPort with speakers in matte black
  • Enhanced connectivity
    Equipped with HDMI, VGA, and DisplayPort interfaces, this monitor offers versatile connectivity options for a wide range of devices, ensuring seamless integration into any workspace.
  • Optimal viewing experience
    Featuring a 19-inch LED-backlit LCD display with a 1280 x 1024 native resolution, the iiyama ProLite T1931SR-B5 delivers crisp, clear images. The monitor's 5:4 image aspect ratio and 1000:1 contrast ratio provide vibrant colors and deep blacks, enhancing the viewing experience.
  • Interactive touchscreen
    Incorporating 5-Wire Resistive Touch Screen Technology, this monitor allows for precise touch control, making it ideal for applications requiring touch interaction. The inclusion of a stylus further enhances accuracy for tasks that demand precision.
  • Ergonomic design
    With display position adjustments including a tilt angle of -5/+90 degrees, users can find their optimal viewing angle, reducing strain during long periods of use. The monitor's ergonomic design promotes comfort and productivity.
  • Efficient and secure
    The iiyama ProLite T1931SR-B5 is designed with energy efficiency in mind, classified as ENERGY STAR with a typical power consumption of 20 W. Additionally, it features a Kensington security slot for physical security.
iiyama ProLite T1931SR-B5 - LED monitor - 19"
LED-backlit LCD monitor - 19" - touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/376495
Energy Class
Class E
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
14.2 W
Touch-screen, stylus
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
Display Position Adjustments
Tilt
Voltage
Matte black
43.2 cm x 21.8 cm x 39 cm
6.6 kg
Plug and Play, VCCI, GOST, DDC-2B, CB, IP54, TUV Bauart
3-year warranty
Display Type
Energy Class
Class E
27 kWh
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Brightness w/touchscreen
200 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31 - 80 KHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
Cable management cover, HDCP, 5-Wire Resistive Touch Screen Technology
Matte black
6.6 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen, stylus - touchscreen
Movement Detection Technology
Resistive
VGA , HDMI , DisplayPort , USB , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x USB cable , 1 x HDMI cable , 1 x audio cable , 1 x DisplayPort cable
Mounting Kit
Included
Security Slot Type
Input Voltage
14.2 W
14.2 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
Limited warranty - 3 years
