iiyama ProLite T1532MSC-B3AG 15" 1024x768 8ms VGA DVI Touch Monitor
Quicklinx: CW41WS00 Mfr#: T1532MSC-B3AG
The ProLite T1532MSC 15" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The anti-glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the touch-screen with an adjustable stand offering full 90-degree positioning angles. Menu Buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the TouchScreen for cleaning. In addition, the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
  • Capacitive touch technology
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • AG coating
    The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
  • IP54 rated
    IP54 means that the monitor will operate in dusty conditions, and will resist splashing water.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
iiyama ProLite T1532MSC-B3AG - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Contrast Ratio
700:1
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 7H Hard Coating
Voltage
35.1 cm x 20.2 cm x 30.65 cm
4.5 kg
VCCI, CB, cULus, IP54, TUV Bauart, CU
Display Type
Diagonal Size
15"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Brightness w/touchscreen
315 cd/m²
Contrast Ratio
700:1
Colour Support
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 60 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
HID Compliant, scratch-resistant
35.1 cm x 20.2 cm x 30.65 cm - with stand
4.5 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA (HD-15) , DVI-D , USB (Type B) , Audio line-in (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
16 Watt
Power Consumption Stand by
2 Watt
Included Software
Driver
Microsoft Windows NT 4.0, Microsoft Windows CE, Linux, Apple MacOS X, Microsoft Windows 2000/XP/Vista/7/8/10
Dimensions & Weight Details
Without stand - width: 35.1 cm - depth: 6.25 cm - height: 27.6 cm , With stand - width: 35.1 cm - depth: 20.2 cm - height: 30.65 cm - weight: 4.5 kg
