iiyama ProLite XUB2493HS-B4 - LED 24" 1920x1080 4ms HDMI VGA
Quicklinx: GLL8WS00 Mfr#: XUB2493HS-B4
Stylish edge-to-edge design makes the ProLite XUB2493HS perfect for multi-monitor set-ups. The IPS panel technology offers accurate and consistent colour reproduction with wide viewing angles. High contrast and brightness values mean the monitor will provide excellent performance for photographic and web design, and the height adjustable stand ensures you can easily adjust the screen position to your preferences. It is a great choice for both multi-monitor Digital Signage and office applications.
IPS TECHNOLOGY
IPS displays are best known for wide viewing angles and natural, highly accurate colours. They are especially suited for colour-critical applications.
HAS + PIVOT
With a height adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width.
FLICKER-FREE + BLUE LIGHT
The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with the blue light reducer function substantially reduce the strain and fatigue caused by flickering and blue light emittance of regular monitors.
SPEAKERS AND HEADPHONES
Playing with friends? Use the integrated high-quality speakers. Don’t want to disturb anybody? Plug your headset into the headphone socket and turn the volume up.
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • IPS technology
    IPS displays are best known for wide viewing angles and natural, highly accurate colors. They are especially suited for color-critical applications.
  • Flicker-free + blue light
    The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with the blue light reducer function substantially reduce the strain and fatigue caused by flickering and blue light emission of regular monitors.
  • Speakers and headphones
    Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset into the headphone socket and turn the volume up.
  • Advanced Contrast Ratio
  • VESA mount compliance
    VESA mount compliance means you can easily mount the display to any mounting that complies with the VESA standard.
iiyama ProLite XUB2493HS-B4 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class E
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC, 96% sRGB
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Matte
Voltage
AC 100-240 V (50/60 Hz)
Matte black
53.95 cm x 21 cm x 37.3 cm
5.7 kg
Environmental Standards
ENERGY STAR Qualified
DDC/CI, RoHS, WEEE, PSE Mark, REACH, TUV Bauart, ERP, VCCI Class B, EAC, REACH SvHC, UKCA
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC, 96% sRGB
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), edge-to-edge glass, X-Res Technology, i-Style Color, Adaptive-Sync technology, Blue Light Reducer Function
Matte black
5.7 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI (HDCP) , DisplayPort , Headphones
Mechanical
Tilt Angle
-5/22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
16 kWh/1000h
Power Consumption (Typical)
16 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Shipping Width
67 cm
Shipping Depth
17 cm
Shipping Height
38.9 cm
Shipping Weight
6.4 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - on-site
