The ProLite E2282HS-B1 is an excellent 22" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 1ms response time and 80 000 000: 1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast. Triple Input support ensures compatibility with the latest installed graphics cards and embedded notebook outputs. The E2282HS is equipped with two high quality stereo speakers. TCO Certified, this monitor is a reliable solution for both home and office use.
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. -
Flicker-free + blue light
The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with the blue light reducer function substantially reduce the strain and fatigue caused by flickering and blue light emittance of regular monitors. -
Speakers and headphones
Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
- iiyama ProLite E2282HS-B1 - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class B
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 21.8 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Screen Coating
- Matte
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 50.5 cm x 19.3 cm x 38.2 cm
- 3 kg
- TUV GS, RoHS, WEEE, VCCI Class B, CU
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 32 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- HDCP, Flicker Free technology, blue light reduction
- Matte black
- 50.5 cm x 19.3 cm x 38.2 cm - with stand
- 3 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- VGA , DVI-D , HDMI , Headphones (mini-jack) , Audio line-in (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable , 1 x audio cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 21.8 W
- Power Consumption (Typical)
- 21 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 50.5 cm - depth: 19.3 cm - height: 38.2 cm - weight: 3 kg , Without stand - width: 50.5 cm - depth: 5.65 cm - height: 31.05 cm
- Limited warranty - 3 years - on-site
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
