The ProLite E2083HSD is a 19.5" LED-backlit monitor with 1600 x 900 resolution. It features 5msec response time and more tan 5M: 1 advanced contrast ratio assuring vibrant images and blur free video. Analog VGA and digital DVI inputs ensure compatibility with the systems and associated graphics cards. The monitor is Energy Star qualified and VESA mount compatible.
LED-backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and makes this LCD a true ECO-friendly product. -
ACR
Advanced contrast ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
VESA
VESA mount compliance means you can easily mount your monitor to a wall. -
Speakers
This LED monitor is equipped with two high quality stereo speakers.
- iiyama ProLite E2083HSD-1 - LED monitor - 20"
- LED-backlit LCD monitor - 20"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/362484
- Energy Class
- Class F
- Power Consumption (On mode)
- 15.4 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900 at 60 Hz
- Pixel Pitch
- 0.271 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 46.95 cm x 20.3 cm x 36 cm
- 2.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, VESA DPMS, DDC/CI, GOST-R, VCCI Class B
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 20"
- Viewable Size
- 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.271 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock, luminance
- OSD Languages
- English, German, French, Italian, Polish, Russian, Spanish, Japanese, Chinese
- HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
- Black
- 2.7 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand, 3 screws
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- 15.4 W
- Power Consumption SDR (On mode)
- 15.4 kWh/1000h
- Power Consumption (Typical)
- 15 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Apple MacOS, Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £7.03 |
