iiyama ProLite B2280WSD-W 22" 1680x1050 5ms VGA DVI-D LED White Monitor with Speakers
Quicklinx: 8W9KWS00 Mfr#: B2280WSD-W1
The ProLite B2280WSD is a high specification 22" 1680 x 1050 LED-backlight monitor with height adjustability and screen rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. 5 millisecond black-to-black response time and 5000000:1 advanced contrast ratio make the B22080WSD ideal for video conferencing, DTP and CAD as well as the usual text based applications. Analog and DVI inputs ensure compatibility with the systems and associated graphics cards.
  • LED-backlight
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-friendly product.
  • ACR
    Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced contrast ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • VESA
    VESA mount compliance means you can easily mount your monitor to a wall.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
  • Height adjustable stand
    A height adjustable stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
  • Pivot
    Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts.
iiyama ProLite B2280WSD-1 - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class E
Power Consumption (On mode)
15.4 W
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Voltage
White
51.25 cm x 24.45 cm x 42.35 cm
5.5 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VESA DPMS
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+85 / -85
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
White
5.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D (HDCP) , VGA , Audio line-in
Mechanical
Tilt Angle
-5/+22
Swivel Angle
320
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand, cable management cover
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
TUV GS, VESA DPMS
Power Supply
Internal
Input Voltage
15.4 W
15.4 kWh/1000h
Power Consumption (Typical)
21 Watt
Power Consumption Stand by / Sleep
1 Watt
Included Software
Drivers & Utilities
Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - on-site
8W9K C2G 2m HDMI to DVI-D Digital Video Cable In Stock £6.94
