The ProLite P1905S meets the increasing demands for protected LCDs within education, retail and industrial applications. In addition to having toughened safety glass fitted behind the bezel at 8H hardness rating capable of resisting above normal impacts to the display, Iiyama have enhanced the range to include the latest high performance and energy saving technology. Features include 5 ms response time, 1000:1 contrast ratio enhancing color and analog and DVI inputs. The displays are ENERGY STAR rated and have 19 W typical power consumption in use and less than 1 W in standby.
Protective glass
The toughened safety glass fitted behind the bezel at 8H hardness rating is capable of resisting above normal impacts to the display making this LCD the ideal choice for Education, Retail and Industrial applications. -
LED-backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product. -
Speakers
This LED monitor is equipped with two high quality stereo speakers. -
Key lock
You can easily lock and unlock the front controls preventing unauthorized changes to settings you made.
- iiyama ProLite P1905S-2 - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Screen Coating
- 8H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 41.45 cm x 20.05 cm x 42.05 cm
- 4.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, VESA DPMS
- Display Type
- Diagonal Size
- 19"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -70
- Screen Coating
- 8H Hard Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, colour balance, input select, phase, clock
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
- Protective Glass Panel
- Black
- 4.6 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI-D , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- 20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable
- TUV GS, VESA DPMS
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 1 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows 95/98/ME/2000/XP/Vista, Microsoft Windows 7 / Windows 8
Sustainability Information
- ENERGY STAR Certified
