iiyama GB2783QSU-B1 27" 2560 x 1440 1ms HDMI DVI DP Gaming Monitor
Quicklinx: CW3PWS00 Mfr#: GB2783QSU-B1
The 27" G-MASTER GB2783QSU opens you to a whole different level of gaming experiences. The Silver Crow makes sure all the finest details are displayed with perfect image clarity. Nothing will skip your attention. The blue light reducer function along with the flicker-free panel are the shield your eyes need to guarantee your vision remains well protected. Armed with FreeSync technology and 1 ms response time the Silver Crow is ready to lead you into the toughest battles, leaving nothing to chance - the faith of your gaming destiny rests in your hands alone.
iiyama G-MASTER Silver Crow GB2783QSU-B1 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
42.6 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Voltage
62.25 cm x 23 cm x 40.05 cm
6.1 kg
TUV GS, DDC-2B, VESA DPMS, DDC/CI, CU
Display Type
Energy Class
Class B
62 kWh
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction
6.1 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort (HDCP) , DVI-D (HDCP) , HDMI (HDCP) , Headphones , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x DisplayPort cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
Input Voltage
42.6 W
Power Consumption (Typical)
44 Watt
Power Consumption Stand by
0.5 Watt
