Fujitsu FI-60F A6 Flatbed Scanner
Quicklinx: 4HHKWS00 Mfr#: PA03420-B001
The compact, lightweight fi-60F scanner is ideal for busy office and retail environments. It quickly scans important, small documents, passports, IDs, prescriptions, driving licenses, customer and medical cards, photographs, and more.
The fi-60F weighs less than 1 kg and has an impressively small footprint of only 145 x 234 mm meaning it is ideally suited for even the smallest desktop, reception, check-in desk or cashier booth.
High-speed USB 2.0 connectivity combines outstanding performance and easy installation. Included TWAIN and ISIS drivers and ScandAll document capture software simplify integration and boost productivity right from the start.
The Fujitsu fi-60F increases user productivity with fast, one-second scanning (at 200 dpi) and coverless scanning. When full detail is needed, the Fujitsu fi-60F scanner delivers clean, crisp scans up to 148 x 105 mm - in color, gray-scale or monochrome - with true, 600 dpi optical resolution. However, when time is critical, users can scan documents at 200 dpi in monochrome or 8-bit gray-scale in just one second. And 24-bit color scans take just 1.7 seconds at 200 dpi.
Coverless scanning eliminates the repetitive task of opening and closing the cover before and after each scan. Simply place documents on the flatbed and scan! Auto-deskew and auto-cropping functions optimize scan size and quality, conserving storage resources and properly orienting scans regardless of how they are placed on the flatbed.
  • The right solution for small-document scanning
    The compact, lightweight Fujitsu fi-60F high-speed scanner is ideal for busy office and retail environments. It quickly scans important, small documents, such as insurance cards, identification cards, credit cards, passports, driver's licenses, photographs, and more.
  • Fast, reliable scanning performance for better productivity
  • No time, no cover, no problem
    The Fujitsu fi-60F scanner increases user productivity with fast, one-second scanning and coverless scanning.
  • Automatic image management features mean consistent scans, every time
    Coverless scanning eliminates the repetitive task of opening and closing the cover before and after each scan, which saves time when there is a high volume of documents to process. Simply place documents on the flatbed scanner and scan!
Fujitsu fi-60F - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
RGB LED array
Max Supported Document Size
A6 (105 x 148 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Size
105 mm x 148 mm
Supported Document Type
Plain paper
Document Feeder Type
Manual
Microsoft Windows 2000 Professional, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 2003, Microsoft Windows Server 2008
23.4 cm x 14.5 cm x 4 cm
0.9 kg
Interface Type
USB 2.0
A6 (105 x 148 mm)
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Scan Mode
Single-pass
Bulb / Light Source Type
RGB LED array
Scanner Speed Details
1 sec/scan - black & white - 200 dpi , 1 sec/scan - greyscale - 200 dpi , 1.7 sec/scan - colour - 200 dpi , 1.3 sec/scan - colour - 150 dpi
TWAIN, ISIS
Media Handling
Max Document Size
105 mm x 148 mm
Plain paper
Manual
Interfaces Details
USB 2.0 - Type B
MTBF
10,000 hours
External power adapter
Power Consumption Operational (Standby)
8 Watt
23.4 cm
14.5 cm
4 cm
0.9 kg
5 °C
35 °C
20 - 80%
