Eaton PW9130i3000T-XL
Quicklinx: 7GY9WS00 Mfr#: 103006437-6591
The Eaton 9130 UPS delivers online power quality and scalable battery runtimes for servers, voice and data networks, storage systems and other IT equipment. With an efficiency rating of 95% in online double conversion and 98% in high efficiency mode the 9130 UPS cuts energy costs while significantly extending battery service life with ABM technology. The 9130 UPS also has a bright LCD user interface to simplify monitoring.
  • Double-conversion design for superior power protection
    The 9130 is constantly monitoring power conditions - regulating both voltage and frequency. Even when presented with the most severe power problems, this UPS's output remains within three percent of nominal voltage.
  • More real power
    High 0.9 output power factor enables the 9130 to provide its full power capability to modern IT equipment that may have a wide range of leading and lagging power factors. With a 0.99 input power factor, this UPS avoids the disturbances that some energy converters tend to cause.
  • Advanced design and self monitoring for premium availability
    The 9130 continually monitors voltage, temperature, internal element functions, battery health, battery state-of-charge and runtime remaining. If the UPS detects a potential problem with any of these measures, it sends alarms or takes corrective action, with no interruption in power. At the end of an alarm condition, the 9130 automatically reverts from bypass to normal operation.
  • Stronger, longer battery life with exclusive ABM technology
    Most UPS manufacturers on the market today employ a constant 'trickle-charging' system, which can ultimately reduce potential battery service life by as much as 50 percent. In contrast, ABM technology uses sophisticated sensing circuitry and an innovative three-stage charging technique that significantly extends UPS batteries' useful service life while optimizing their recharge time.
  • External battery modules for extended runtime
    During a power outage, internal batteries in the 9130 keep loads running long enough to gracefully shut down systems. Add more runtime at any time, with up to four external battery modules to run systems for hours if necessary. These battery modules are hot-swappable and can be replaced at any time without powering down the UPS or protected loads. You can also start up the UPS and power its loads with battery power.
Eaton PW9130i3000T-XL - UPS - 2.7 kW - 3000 VA
UPS - external
34.5 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
2.7 kW / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid - 9 Ah
Battery Form Factor
Internal
Batteries Qty
4
Run Time (Up To)
6 min at full load
RS-232, USB
Cable retention brackets
21.4 cm x 41 cm x 32.5 cm
UPS - external
Battery Enclosure Type
Internal
UPS Technology
On-line
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 276 V
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 230 V ± 3%
Power Capacity
2.7 kW / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Efficiency
95%+
Quantity
4
Lead Acid
Voltage Provided
12 V
9 Ah
Run Time (Up To)
6 min at full load
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x Communication slot
USB cable - external
Advance Battery Management (ABM), audible alarm, LCD display, internal bypass, LED indicators, automatic self-test
GS, EN 62040-2
Software Included
Eaton Software Suite
Limited warranty - parts and labour - 2 years
5 - 90% (non-condensing)
Sound Emission
50 dB
21.4 cm
41 cm
32.5 cm
34.5 kg
