Eaton 9PX EBM 180V 5kVA & 6kVA
Quicklinx: B66DWS00 Mfr#: 9PXEBM180
Type: UPS
Power Rating: 6000VA
£1,143.39 ex VAT
£1,372.06 inc VAT
180V Extended battery module for the Eaton 9PX. The Eaton 9PX UPS provides energy efficient power protection for small & medium Datacenters, IT rooms and Infrastructure. Delivering double conversion protection with 40% less energy usage and 28% more power 9PX is the perfect UPS for IT and Facility managers that are concerned by energy cost and are looking for next generation power protection solutions.
  • Graphical LCD display
    It provides clear information on the UPS's status and measurements on a single screen which tilts 450 for ease-of-viewing.
  • Availability and flexibility
    The internal bypass allows service continuity in case of internal fault, a maintenance bypass is also available for easy replacement of the UPS without powering down critical systems.
  • Paralleling functionality
    Paralleling functionality to achieve twice the power of unitary products using Hot Sync technology!
  • Load segment control
    It enables prioritized shut downs of nonessential equipment to maximize battery runtime for critical devices.
Eaton 9PX 9PXEBM180 - battery enclosure - Lead Acid
Battery enclosure - rack-mountable / external
Rack Size
19" - 3U
68 kg
Output Voltage
180 V
Lead Acid
Battery Form Factor
Internal
44 cm x 64.5 cm x 13 cm
9PX 9PX5KIBP, 9PX5KIRTN, 9PX6KIBP, 9PX6KIRTN
Battery Enclosure Type
Internal
Height (Rack Units)
3U
Rack Size
19"
Output Voltage
180 V
Lead Acid
Power cable 40 cm
Rack Mounting Kit
Optional
44 cm
64.5 cm
13 cm
68 kg
Eaton 9PX 9PX5KIBP, 9PX5KIRTN, 9PX6KIBP, 9PX6KIRTN
Type: UPS
Brand: Eaton
Price Range Ex VAT: £1000 - £1500
