Eaton 9PX EBM 240V 8kVA & 11kVA
Quicklinx: CBNJWS00 Mfr#: 9PXEBM240
Hurry, only 2 left in stock!
£1,459.67 ex VAT
£1,751.60 inc VAT
Extended battery module for the Eaton 9PX. The Eaton 9PX UPS provides energy efficient power protection for small & medium Datacenters, IT rooms and Infrastructure. Delivering double conversion protection with 40% less energy usage and 28% more power 9PX is the perfect UPS for IT and Facility managers that are concerned by energy cost and are looking for next generation power protection solutions.
  • Graphical LCD display
    It provides clear information on the UPS's status and measurements on a single screen which tilts 450 for ease-of-viewing.
  • Availability and flexibility
    The internal bypass allows service continuity in case of internal fault, a maintenance bypass is also available for easy replacement of the UPS without powering down critical systems.
  • Paralleling functionality
    Paralleling functionality to achieve twice the power of unitary products using Hot Sync technology!
  • Load segment control
    It enables prioritized shut downs of nonessential equipment to maximize battery runtime for critical devices.
Eaton 9PX 9PXEBM240 - battery enclosure - Lead Acid
Battery enclosure - rack-mountable / external
Rack Size
19" - 3U
65 kg
Output Voltage
240 V
Lead Acid
Battery Form Factor
Internal
44 cm x 68 cm x 13 cm
9PX 9PX11KIBP, 9PX11KIBP31, 9PX11KIRTNBP, 9PX11KIRTNBP31, 9PX6KIBP31, 9PX6KIRTNBP31, 9PX8KIBP, 9PX8KIBP31, 9PX8KIRTNBP, 9PX8KIRTNBP31
Battery Enclosure Type
Internal
Height (Rack Units)
3U
Rack Size
19"
Output Voltage
240 V
Lead Acid
Power cable 40 cm
Rack Mounting Kit
Optional
44 cm
68 cm
13 cm
65 kg
Eaton 9PX 9PX11KIBP, 9PX11KIBP31, 9PX11KIRTNBP, 9PX11KIRTNBP31, 9PX6KIBP31, 9PX6KIRTNBP31, 9PX8KIBP, 9PX8KIBP31, 9PX8KIRTNBP, 9PX8KIRTNBP31
Brand: Eaton
Price Range Ex VAT: £1000 - £1500
