Eaton Powerware 5110 1000 VA
Quicklinx: 7GYKWS00 Mfr#: 103004263-5591
The Powerware 5110 uninterruptible power system (UPS) was designed to provide the best UPS power protection against the threats that lurk in public utilities. This line-interactive UPS system delivers the ultimate in power quality, constantly safeguarding your equipment from power outages, surges, sags, brownouts, and over-voltage conditions - while also providing varying degrees of power management for additional threats. If utility power is interrupted, even briefly, the Powerware 5110 transfers to UPS battery power.
Eaton 5110 - UPS - 600 Watt - 1000 VA
UPS - external
12 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V + 10% / - 10%
Power Capacity
600 Watt / 1000 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13 (surge) , 4 x power IEC 60320 C13 (UPS and surge)
Lead Acid
Battery Form Factor
Internal
Run Time (Up To)
3 min at full load
USB
8.7 cm x 38.4 cm x 27 cm
3-year warranty with product registration
UPS - external
Battery Enclosure Type
Internal
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 178 - 275 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V + 10% / - 10% - 50/60 Hz
Power Capacity
600 Watt / 1000 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11 - 1 input line / 1 output line
Surge Suppression
Surge Energy Rating
476 Joules
Circuit Protection
Circuit breaker
Efficiency
95%
Lead Acid
Run Time (Up To)
3 min at full load
Remote Management Interface
USB
1 x management (USB) - 4 pin USB Type B
Power cable - integrated - 1.8 m , 2 x power cable - external , USB cable - external , Phone cable - external
Audible alarm, Automatic Voltage Regulation (AVR), LED indicators
Plug and Play, FCC Class B certified, UL 1778, UL 497A, EN55022 Class B, EMC, CSA C22.2 No. 107.1, RoHS, EN 62040-1-1, EN 62040-2
Software Included
Eaton LANSafe
Limited warranty - parts and labour - 3 years
0 - 95% (non-condensing)
Sound Emission
40 dB
8.7 cm
38.4 cm
27 cm
12 kg
