Eaton 5P 650i Rack 1U Netpack G2
Quicklinx: HYDBWS00 Mfr#: 5P650IRNG2BS
Power Rating: 520watt
21 In Stock
£588.80 ex VAT
£706.56 inc VAT
The Eaton 5P Gen2 650i UPS delivers reliable power protection with advanced features designed for efficiency and performance. With a power capacity of 650 VA and providing up to 520 watts, this UPS ensures consistent operation for connected devices. The line-interactive technology stabilizes voltage fluctuations, while the Automatic Voltage Regulation (AVR) and Advanced Battery Management (ABM) enhance battery lifespan and reliability. The intuitive LCD display offers real-time monitoring, and the UPS boasts a high efficiency rating of 97%, maximizing energy savings. The compact, rack-mountable form factor allows for easy installation in various environments without compromising performance. Equipped with hot-swappable batteries, this UPS ensures uninterrupted power during maintenance. Multiple connectivity options, including USB and RS-232 management interfaces, provide flexible remote management capabilities. Moreover, the UPS is compliant with various standards, ensuring safety and environmental responsibility. Suitable for mission-critical applications, the Eaton 5P Gen2 650i UPS combines reliability, efficiency, and advanced technology.
  • Reliable backup power
    The Eaton 5P Gen2 650i UPS is designed to provide consistent backup power, ensuring that connected devices remain operational during outages. With a sine wave output and a transfer time of only 6 ms, the UPS delivers stable power quickly to sensitive equipment.
  • Flexible connectivity options
    Featuring multiple communication interfaces, including USB and RS-232, this UPS supports seamless integration with management systems, enhancing remote monitoring and control capabilities. The variety of connection cables provided ensures compatibility with different setups.
  • Environmentally compliant design
    The Eaton 5P Gen2 650i UPS complies with multiple environmental and safety standards, including UL 1778, RoHS, and WEEE. This commitment to compliance reflects a dedication to minimizing environmental impact while ensuring reliable performance.
Eaton 5P Gen2 650i - UPS - 520 Watt - 650 VA
UPS - rack-mountable
Rack Size
19" - 1U
8.863 kg
Input Wiring
1-phase
Input Voltage
AC 200/208/220/230/240 V
Output Voltage
AC 200/208/220/230/240 V + 6% / - 10%
Power Capacity
520 Watt / 650 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13
Lead Acid - 9 Ah
Batteries Qty
2
RS-232, USB, Ethernet 10/100/1000
Remote Management Protocol
SNMP 1, SNMP 3, IPv4, IPv6, HTTPS
Cable locking system, network management card
Black/silver
43.8 cm x 36.1 cm x 4.32 cm
3-year warranty
Height (Rack Units)
1U
Rack Size
19"
Black/silver
UPS Technology
Line interactive
Input Voltage
Input Voltage Range
AC 160 - 294 V
Input Voltage Range (Adjustable)
AC 150 - 294 V
Frequency Provided
50/60 Hz
Input Wiring
1-phase
Frequency Required
47 - 70 Hz
Input Connectors
Output Voltage
AC 200/208/220/230/240 V + 6% / - 10% - 50/60 Hz
Power Capacity
520 Watt / 650 VA
Output Waveform
Sinewave
Efficiency
97%
Power Factor (PF)
0.8
Quantity
2
Lead Acid
Voltage Provided
DC 6 V
9 Ah
Transfer Time
6 ms
Maintenance free, sealed, hot-swappable, valve-regulated
Remote Management Interface
1 x RPO/ROO - mini terminal block , 1 x management (USB) - 4 pin USB Type B , 1 x management (RS-232) , 1 x management (Gigabit Ethernet) - RJ-45
Expansion Slots
1 (total) / 0 (free) x Communication slot
2 x connection cable - external , Communication cable - external , 3 x power cable - external
Rack Mounting Kit
Included
Advance Battery Management (ABM), discharge protection, automatic battery test, automatic shut down, LCD display, LED indicator, Automatic Voltage Regulation (AVR)
LVD, EMC, RoHS, WEEE, IEC/EN 62040-1, IEC/EN 62040-2, IEC/EN 62040-3, UL 1778, CSA 22.2, UKCA, CM, UKR, KCC, cTUVus, BIS
Limited warranty - 3 years
0 - 90% (non-condensing)
Sound Emission
35 dB
43.8 cm
36.1 cm
4.32 cm
8.863 kg
Brand: Eaton
Price Range Ex VAT: £500 - £750
