Eaton 9PX 1500i RT2U - UPS - 1500 watt - 1500 VA
Quicklinx: HTJ1WS00 Mfr#: 9PX1500IRT2U-L
The Eaton 9PX UPS provides advanced protection for small & medium Datacenters, IT rooms and Infrastructure. Delivering double conversion protection and being the first in its class to provide Unity power factor (VA=W).
  • Graphical LCD display
    It provides clear information on the UPS's status and measurements on a single screen which tilts 450 for ease-of-viewing.
  • Availability and flexibility
    The internal bypass allows service continuity in case of internal fault, a maintenance bypass is also available for easy replacement of the UPS without powering down critical systems.
  • Paralleling functionality
    Paralleling functionality to achieve twice the power of unitary products using Hot Sync technology!
  • Load segment control
    It enables prioritized shut downs of nonessential equipment to maximize battery runtime for critical devices.
UPS - Power Factor Correction (PFC) - rack-mountable / external
Rack Size
19" - 2U
15.8 kg
Input Wiring
1-phase
Input Voltage
AC 200/208/220/230/240 V
Output Voltage
AC 200/208/220/230/240 V ± 1%
Power Capacity
1500 watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
8 x power IEC 60320 C13
Lithium ion
Run Time (Up To)
10 min at full load
RS-232, USB
Black/silver
44 cm x 45 cm x 8.65 cm
Environmental Standards
ENERGY STAR
5-year warranty
Height (Rack Units)
2U
Rack Size
19"
Black/silver
UPS Technology
On-line
Input Voltage
Input Voltage Range
AC 176 - 276 V
Frequency Provided
50/60 Hz
Input Wiring
1-phase
Frequency Required
40 - 70 Hz
Input Connectors
Output Voltage
AC 200/208/220/230/240 V ± 1% - 50/60 Hz
Power Capacity
1500 watt / 1500 VA
Output Waveform
Sinewave
Efficiency
92.5%, 97.5% Eco mode
Power Factor (PF)
0.99
Lithium ion
Remote Management Interface
RS-232, USB
1 x management (USB) , 1 x management (RS-232) , 1 x remote power (on/off) - terminal block , 1 x relay output - terminal block , 3 x dry contact output , 1 x dry contact input
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
2 x power cable - external , USB cable - external , Serial cable - external
Rack Mounting Kit
Included
LCD display, internal bypass, automatic shut down
Software Included
Eaton Intelligent Power Protector, Intelligent Power Manager
Sustainability Information
ENERGY STAR
Limited warranty - 5 years
0 - 95% (non-condensing)
Sound Emission
35 dB
44 cm
45 cm
8.65 cm
15.8 kg
