DrayTek VigorSwitch G2280 Ethernet Switch
Quicklinx: DPKQWS00 Mfr#: VSG2280-K
The VigorSwitch G2280 is an L2 managed switch designed for small- to medium-sized businesses. To cater for high-bandwidth traffic, it is equipped with several Gigabit Ethernet ports for the LAN side, and 4 combo UTP/SFP ports for the backbone side.
  • Virtual LAN
    VLAN provides a way for businesses to assign network functions to different workgroups, branches, sections, employees or visitors, according to their operational requirements.
  • Bandwidth aggregation
    The Gigabit ports can be combined together to create a multilink load-sharing trunk. Port trunks are useful for switch-to-switch cascading, providing high full-duplex speeds.
  • Energy efficiency
    The power saving uses power management techniques to detect the client idle and cable length automatically and provides the suitable power.
Draytek VigorSwitch G2280 - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x combo Gigabit SFP
Multicast groups: 256 , Total link aggregation groups: 8
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Flow control, DHCP support, auto-negotiation, load balancing, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, SSH support, MLD snooping, IPv4 support, LACP support, LLDP support, Link Aggregation Control Protocol (LACP), Traffic Control, port based access control, Multicast VLAN Registration (MVR), Multicast filtering function, Class of Service (CoS), Strict Priority (SP), DiffServ Code Point (DSCP) support, Protocol-based VLANs support, IP source guard, ARP inspection, Voice VLAN, VLAN management, LLDP-MED, Guest VLAN, protected ports, Energy-Efficient Ethernet (EEE), Weighted Round Robin (WRR)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az, IEEE 802.3q, IEEE 802.1az
AC 120/230 V
44.1 cm x 19.7 cm x 4.5 cm
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS
28 x 1000Base-T RJ-45 , 4 x Gigabit LAN SFP , 1 x console RJ-45 management
Internal power supply
AC 120/230 V
Rack Mounting Kit
Included
44.1 cm
19.7 cm
4.5 cm
10 - 90% (non-condensing)
