DrayTek VigorSwitch G2500 50-Port Gigabit Switch
Quicklinx: F9QKWS00 Mfr#: VSG2500-K
DrayTek VigorSwitch G2500 is a Layer 2 Managed Gigabit switch. It has 44x Gigabit Ethernet ports, 4x GbE/SFP combo ports, 2x SFP ports, 1x console port, and enterprise-level features to help businesses to improve network security and stability.
  • Auto surveillance VLAN
    Recognize traffic from IP cameras and IP phones automatically and add CoS tag for QoS prioritization.
  • QoS (Quality of Service)
    Improve the performance of critical traffic by prioritizing the traffic with CoS, DSCP, and IP Precedence tag.
  • IP conflict prevention
    Improve network stability by avoiding IP conflicts caused by a misconfigured or malicious host.
  • Access Control
    VigorSwitch G2500 supports ACL by IP/MAC and 802.1x port access control with RADIUS to filter unauthorized hosts.
  • IPv6 ready
    VigorSwitch G2500 supports IPv6 by offering MLD Snooping, IPv6 ACL, and IPv6 DNS Resolver.
  • Multiple Admin accounts
    Multiple Admin accounts with two levels of administrator privilege.
  • Central switch management
    Set up VLAN easily from the router and get a centralized hierarchy view of the switches. Learn more
  • Energy-efficient Ethernet
    Compliant with IEEE 802.3az to reduce power consumption.
Draytek VigorSwitch G2500 - switch - 50 ports - Managed - rack-mountable
Switch - 50 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
44 x 10/100/1000 + 4 x combo Gigabit SFP + 2 x SFP
Performance
Switching capacity: 56 Gbps , Forwarding rate: 41.7 Mpps , Packet buffer size: 12 Mbit
Multicast groups: 256 , Total link aggregation groups: 16 , Links per group: 8 , ACL entries: 512
MAC Address Table Size
16K entries
Jumbo Frame Support
12KB
Routing Protocol
IGMPv2, IGMPv3, MLDv2, MLD, MSTP, STP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI, TR-069, RSTP
Flow control, DHCP support, auto-negotiation, trunking, load balancing, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, RADIUS support, SSH support, MLD snooping, reset button, IPv4 support, fanless, LACP support, LLDP support, LACP, Traffic Control, port based access control, MVR, Multicast filtering function, CoS, SP, DSCP support, Protocol-based VLANs support, IP source guard, ARP inspection, Voice VLAN, VLAN management, LLDP-MED, Guest VLAN, protected ports, EEE, WRR, VLAN Tagging, port-based VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az, IEEE 802.3q, IEEE 802.1az
44.1 cm x 27 cm x 4.5 cm
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
12KB
Routing Protocol
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
Status Indicators
Port transmission speed, power, system, link/activity
44 x 1000Base-T RJ-45 , 4 x Gigabit LAN RJ-45/SFP , 1 x console RJ-45 management , 2 x Gigabit LAN SFP
Internal power supply
Rack Mounting Kit
Included
44.1 cm
27 cm
4.5 cm
45 °C
10 - 90% (non-condensing)
