DrayTek VigorSwitch P2500 is a Layer 2 Managed Gigabit PoE switch. It has 44x Gigabit Ethernet PoE/PoE+ ports with a power budget of 405 watts. Perfect for a business network with many PoE devices. It also has 4x GbE/SFP combo ports, 2x SFP ports, 1x console port, and enterprise-level features to help businesses to improve network security and stability.
                PoE (Power over Ethernet)Deliver power and data over one Ethernet cable, turn on/off the PoE device periodically with PoE Schedule.
                PoE device checkEnable Ping Watchdog for all PoE devices, if they lose their network connection, automatically restart them by a power cycle.
                Auto surveillance & voice VLANRecognize traffic from IP cameras and IP phones automatically and add CoS tag for QoS prioritization.
                IP conflict preventionImprove network stability by avoiding IP conflicts caused by a misconfigured or malicious host. Learn more
                Access controlVigorSwitch P2500 supports ACL by IP/MAC and 802.1x port access control with RADIUS to filter unauthorized hosts.
                ONVIF-friendlyRecognize the ONVIF devices, display surveillance topology, provide UI for video streaming and device maintenance.
                QoS (Quality of Service)Improve the performance of critical traffic by prioritizing the traffic with CoS, DSCP, and IP Precedence tag.
                IPv6 readyVigorSwitch P2500 supports IPv6 by offering MLD Snooping, IPv6 ACL, and IPv6 DNS Resolver.
                Multiple Admin accountsMultiple Admin accounts with two levels of administrator privilege.
                Central switch managementSet up VLAN easily from the router and get a centralized hierarchy view of the switches. Learn more
                Energy-efficient EthernetCompliant with IEEE 802.3az to reduce power consumption.
- Draytek VigorSwitch P2500 - switch - 50 ports - Managed - rack-mountable
- Switch - 50 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 44 x 10/100/1000 (PoE+) + 4 x combo Gigabit SFP + 2 x SFP
- Power Over Ethernet (PoE)
- PoE+
- Performance
- Switching capacity: 56 Gbps , Forwarding rate: 41.7 Mpps , Packet buffer size: 12 Mbit
- Capacity
- Multicast groups: 256 , Total link aggregation groups: 16 , Links per group: 8 , ACL entries: 512
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 12KB
- Routing Protocol
- IGMPv2, IGMPv3, MLDv2, MLD, MSTP, STP
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI, TR-069, RSTP
- Flow control, DHCP support, auto-negotiation, trunking, load balancing, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, RADIUS support, SSH support, MLD snooping, reset button, IPv4 support, fanless, LACP support, LLDP support, LACP, Traffic Control, port based access control, MVR, Multicast filtering function, CoS, SP, DSCP support, Protocol-based VLANs support, IP source guard, ARP inspection, Voice VLAN, VLAN management, LLDP-MED, Guest VLAN, protected ports, EEE, WRR, VLAN Tagging, port-based VLAN
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.3q, IEEE 802.1az
- 44.1 cm x 27 cm x 4.5 cm
- 2-year warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- Performance
- Capacity
- 16K entries
- 12KB
- Routing Protocol
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- Status Indicators
- Port transmission speed, power, system, link/activity
- 44 x 1000Base-T RJ-45 , 4 x Gigabit LAN RJ-45/SFP , 1 x console RJ-45 management , 2 x Gigabit LAN SFP
- Power Device
- Internal power supply
- Rack Mounting Kit
- Included
- 44.1 cm
- 27 cm
- 4.5 cm
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
