What is a patch panel? Think of it as an old fashioned switchboard. A place where network connections are made and often rearranged, guiding the information to the correct destination, each and every time. And since you don't want to change your patch panel every time you upgrade your network, Belkin's built this one to meet the new enhanced Category 5e requirements. This 48 port CAT 5e patch panel is 19 inch rack mountable and supports both 568A and 568B installations. Compatible with both 110 and Krone punch down tools.
- Belkin patch panel - 19"
- Product Type
- Patch panel - CAT 5e
- Black
- Port Qty
- 48 ports
- Limited lifetime warranty
- Product Type
- Enclosure Colour
- Black
Cabling & Wiring
- Port Qty
- 48 ports
- Connector Provided
- 48 x RJ-45 female
- Rack Size
- 19"
- Limited warranty - lifetime
