The model TC-P12C6 provides a 250MHz connection to 12 x Gigabit RJ-45 Ethernet ports. This 10-inch wide patch panel is well suited for home and SMB applications. Control cable clutter with included removable cable pass-through holders and cable ties. A writing surface above each port allows users to label respective connections.
- TRENDnet patch panel
- Product Type
- Patch panel - CAT 6 - RJ-45 X 12
- Port Qty
- 12 ports
- Wiring Scheme
- T568B
- UL
- Product Type
Cabling & Wiring
- Port Qty
- 12 ports
- Termination Type
- 110 type termination
- Wiring Scheme
- T568B
- Connector Provided
- 12 x RJ-45 female
- UL
- -40 °C
- 80 °C
