TRENDnet 8-Port Cat. 6 Unshielded Patch Panel (10" wide)
Quicklinx: 9YP9WS00 Mfr#: TC-P08C6
The model TC-P08C6 provides a 250MHz connection to 8 x Gigabit RJ-45 Ethernet ports. This 10-inch wide patch panel is well suited for home and SMB applications. Control cable clutter with included removable cable pass-through holders and cable ties. A writing surface above each port allows users to label respective connections.
TRENDnet patch panel
Patch panel - CAT 6
4.4 cm x 25.4 cm x 3 cm
205 g
Port Qty
8 ports
FCC, RoHS
Patch panel - CAT 6
4.4 cm
25.4 cm
3 cm
205 g
Cabling & Wiring
Port Qty
8 ports
Termination Type
110 type termination
Connector Provided
8 x RJ-45 female
FCC, RoHS
-10 °C
60 °C
