The 8-port CAT 5e unshielded patch panel provides a 100MHz connection to 8 x Gigabit RJ-45 Ethernet ports. This 10-inch wide patch panel is well suited for home and SMB applications. A writing surface above each port allows users to label respective connections.
- TRENDnet patch panel - 10"
- Product Type
- Patch panel - CAT 5e - RJ-45 X 8
- 4.4 cm x 25.4 cm x 3 cm
- 205 g
- Port Qty
- 8 ports
- FCC, RoHS
- 2-year warranty
- Product Type
- 4.4 cm
- 25.4 cm
- 3 cm
- 205 g
Cabling & Wiring
- Port Qty
- 8 ports
- Termination Type
- 110 type termination, LSA (Krone)
- Technology
- Connector Provided
- 8 x RJ-45 female
- Rack Size
- 10"
- Weight Limit
- 7.7 kg
- FCC, RoHS
- Limited warranty - 2 years
- -10 °C
- 60 °C
