TC-P12C5E unshielded patch panel provides a 100MHz connection to 8 x Gigabit RJ-45 Ethernet ports. This 10-inch wide patch panel is well suited for home and SMB applications. Control cable clutter with included removable cable pass-through holders and cable ties. A writing surface above each port allows users to label respective connections.
- TRENDnet patch panel
- Product Type
- Patch panel - CAT 5e
- 4.4 cm x 25.4 cm x 3 cm
- 230 g
- Port Qty
- 12 ports
- FCC
- 2-year warranty
- Product Type
- 4.4 cm
- 25.4 cm
- 3 cm
- 230 g
Cabling & Wiring
- Port Qty
- 12 ports
- Termination Type
- 110 type termination
- Connector Provided
- 12 x RJ-45 female
- FCC
- Limited warranty - 2 years
- -10 °C
- 60 °C
