Prepare yourself for Copper Gigabit Ethernet with TRENDnet's Cat. 6 RJ-45 UTP Patch Panels. These patch panels are certified for 250Mhz Category 6, which are perfect for Copper Gigabit Ethernet connections. TRENDnet's 16/24/48-port Cat. 6 Patch Panels are ideal for Ethernet, Fast Ethernet and Copper Gigabit Ethernet (1000Base-T) network applications. Using TRENDnet's Cat. 6 products now, will prepare you for the high bandwidth network in the future without re-cabling your network.
- TRENDnet patch panel
- Product Type
- Patch panel - CAT 6
- Port Qty
- 16 ports
- Wiring Scheme
- T568B
- UL
- 1-year warranty
- Product Type
Cabling & Wiring
- Port Qty
- 16 ports
- Termination Type
- 110 type termination
- Wiring Scheme
- T568B
- Connector Provided
- 16 x RJ-45 female
- UL
- Limited warranty - 1 year
- -40 °C
- 80 °C
