The ZyXEL MS-7206S modular chassis switch comes with intelligent L2/L3/L4 local switching and advanced management features. OSPF ensures rapid determination of best routes (convergence), avoid routing loops. Rapid spanning tree provides Layer 2 resilience and prevent loops. VRRP ensures hosts (PCs) have uninterrupted service from default gateway.
Unbeatable performance and scalability
Implement campus and building backbone networks support thousands of users. -
Fault-free with automatic recovery
OSPF ensures rapid determination of best routes (convergence), avoid routing loops. Rapid spanning tree provides Layer 2 resilience and prevent loops. -
Secured connectivity
Sophisticated Layer 2 to Layer 4 ACL (Access Control List) makes security policy to be applied at LAN easily.
- Zyxel MS-7206S Fibre Bundle - switch - 24 ports - Managed
- Switch - 24 ports - L4 - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 24 x SFP
- Routing Protocol
- RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, static IP routing, IGMPv3
- Remote Management Protocol
- RMON 1, RMON 2, SNMP, RMON 3, RMON 9, SNMP 2c, HTTP
- Flow control, modular design, hot swap module replacement, Layer 4 switching, Layer 3 switching, Layer 2 switching, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, manageable, WRR queuing, MAC address filtering, Broadcast Storm Control, firmware upgradable, WFQ, ACL support, QoS
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 43.5 cm x 31.6 cm x 44.7 cm
- 15.5 kg
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), Secure Shell v.2 (SSH2)
- Status Indicators
- Power, system, status
- 24 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x 10Base-T/100Base-TX - RJ-45 management , 1 x RS-232 - 9 pin D-Sub (DB-9) management , Accessory: 1 x RS-232 - 9 pin D-Sub (DB-9) , 24 x SFP (mini-GBIC)
- Expansion Slots
- 6 (total) / 3 (free) x Expansion Slot
- Installed Modules Qty (Max)
- 3 (installed) / 6 (max)
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Voltage Required
- 600 Watt
- 43.5 cm
- 31.6 cm
- 44.7 cm
- 15.5 kg
