Zyxel GS1920-48v2, 50 Port Smart Managed Switch
Quicklinx: HHYTWS00 Mfr#: GS1920-48V2-GB0101F
10 In Stock
£248.36 ex VAT
£298.03 inc VAT
The GS1920 series is ideal for SMB deployment in multiple scenarios, with its unique port combinations future proofing your network to ensure easy growth down the road.
  • Whisper-quiet operation
    Smart fan and fanless designs for silent operation in your workplace.
  • User-friendly LED indicators
    View real-time status instantly with cloud and PoE power-usage LED indicators.
Zyxel GS1920-48v2 - switch - 48 ports - smart - rack-mountable
Switch - 48 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x combo Gigabit SFP + 2 x Gigabit SFP
Performance
Switching capacity: 100 Gbps , Forwarding rate: 75 Mpps
QoS hardware queues per port: 8
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c
Flow control, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, MAC address filtering, Broadcast Storm Control, IPv6 support, IP address filtering, Multicast Storm Control, Unicast Storm Control, firmware upgradable, WFQ, ZyXEL iStacking Technology, STP support, RSTP support, MSTP support, DHCP snooping, QoS, RADIUS support, MLD snooping, DHCP relay, Port Security, SNMP trap, DHCP client, MIB, MVR, GVRP, dual firmware images, SPQ, NDP, port isolation, CoS, IGMP proxy, 802.1x authentication, Duplicated Address Detection, cloud managed, DSCP support, 1.5MB packet buffer, ErrDisable Recovery, IGMP filtering, IGMP throttling, Protocol-based VLANs support, CPU protection, IP source guard, ARP inspection, ICMP, VLAN filtering, Loop Guard, Voice VLAN, Private VLAN, Guest VLAN, WRR, MAC based VLAN, VLAN Tagging, port-based VLAN, Unknown Storm Control, MRSTP, MAC freeze
IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
44 cm x 20 cm x 4.45 cm
2.8 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+
RAM
256 MB
Flash Memory
32 MB
48 x 1000Base-T RJ-45 , 4 x 1000Base-X SFP , 2 x 1000Base-X SFP
Internal power supply
36.9 Watt
Rack Mounting Kit
Included
MTBF
672,235 hours
BSMI, RoHS, FCC Part 15 A, LVD, EMC Class A
United Kingdom
44 cm
20 cm
4.45 cm
2.8 kg
Shipping Width
49.6 cm
Shipping Depth
28.9 cm
Shipping Height
9 cm
Shipping Weight
3.97 kg
Limited warranty - lifetime
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Brand: Zyxel
