The MES-3728's high-performance hardware platform and physical features enable service providers to easily extend network topologies, while the robust security and management functions help customers to fulfill differentiated metro Ethernet service needs. The MES-3728 not only represents ZyXEL's entry into the metropolitan Ethernet networking arena, but also demonstrates the company's technical capability on metro Ethernet deployments.
Secure multi-service delivery and quality
The ZyXEL MES-3728 is a carrier-class Ethernet switch based on a high-performance hardware platform with robust security, Quality of Service (QoS) and management features to deliver intelligent connectivity for differentiated metro Ethernet services. With features like VLAN stacking and VLAN translation, it is capable of isolating individual customer traffics from internal signaling of the core networks. -
Advance mechanical design for metro Ethernet
Designed for metro Ethernet deployments, The MES-3728 offers high operating temperature tolerance, flexible AC/DC dual-input power source as well as protection against humidity and dust for service providers to extend their networks. Since MES-3728 adopts the "front access" design, technicians can easily wire and maintain outdoor cabinets; the external alarm input/output block connects mechanical cabinet parts to the management networks and offers higher protection to the equipment.
- Zyxel MES-3728 - switch - 24 ports - Managed
- Switch - 24 ports - Managed
- Subtype
- Fast Ethernet
- Ports
- 24 x 10/100 + 2 x SFP + 2 x combo Gigabit SFP
- Performance
- Switching capacity: 12.8 Gbps , Forwarding performance: 9.6 Mpps
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c
- ARP support, VLAN support, IGMP snooping, MAC address filtering, firmware upgradable, WFQ, DHCP snooping, ACL support, QoS, temperature / humidity sensor, DHCP relay, IP-MAC binding
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ag
- Power
- AC 120/230 V / DC -48 -60 V (50/60 Hz)
- 43.8 cm x 22.5 cm x 4.5 cm
- 3.4 kg
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- Performance
- 16K entries
- 9KB
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- 24 x 10Base-T/100Base-TX - RJ-45 , 2 x 1000Base-T - RJ-45 , 4 x SFP (mini-GBIC) , 1 x serial (RS-232) , 1 x console - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- MTBF
- 307,007 hours
- RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1
- 43.8 cm
- 22.5 cm
- 4.5 cm
- 3.4 kg
- 0 °C
- 65 °C
- 10 - 99% (non-condensing)
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 70 °C
