The ZyXEL GS1910 series 24-port GbE smart managed switch is a smart switch. The GS1910 series is ideal for securing 10/100, Gigabit and 10GbE connectivity; it also offers IEEE 802.3az, access security, advanced prioritization and traffic-monitoring capabilities. As a result, the GS1910 series is suitable for fulfilling SMB network needs with cost-effective, valuable frameworks.
Smart Managed Switch Embracing Greater Bandwidth and Future-proof Technologies
Smart Layer 2 features enrich access networks
The ZyXEL XGS1910/GS1910 Series consists of full-featured GbE Ethernet switches providing comprehensive Layer 2 switching capabilities such as Access Control List (ACL) rules and 802.1AB LLDP and LLDP-MED, etc. The Series delivers the essential network features for businesses with easy-to-use management at a right price. That is, the XGS1910/GS1910 Series is the best Edge switch range for small- and medium-size businesses to build high-performance network efficiently.
GbE bandwidth for desktops
When videos of higher resolution and data flow constantly evolve, network user demands might not be satisfied and business operations hampered by insufficient bandwidth. The ZyXEL XGS1910/GS1910 Series provides GbE bandwidth to desktops to ensure sufficient bandwidth for all business communications, data delivery and daily operations. Taking advantages of GbE, businesses can create premium worry-free IT environment and expand operations with desirable efficiency and productivity.
Energy management with IEEE 802.3az and IEEE802.3at PoE Plus
As operating overheads such as electric bills increase constantly due to the rising green awareness, businesses have to avoid unnecessary energy waste. The built-in IEEE 802.3az Energy Efficient Ethernet (EEE) features of ZyXEL XGS1910/GS1910 Series can reduce energy consumption of Ethernet devices through defining low-power modes and adjusting the operating timeframe to help saving the related costs effectively.
Meanwhile, although IEEE 802.3af is insufficient for providing power to large-scale network deployments or high-power devices such as outdoor Wi-Fi APs, IP cams and IP phones, fortunately the ZyXEL GS1910 Series features IEEE 802.3at PoE Plus with up to 30W power per port to flexibly extend network deployments. 802.3at PoE Plus makes the switch ideal for connecting numerous powered devices to form a flawless business network.
Optional 10GbE uplink for flexible data delivery
Ready for the future 10 Gigabit Ethernet, the ZyXEL XGS1910 Series collocates 2/4 10GbE connectivity for uplinks that allow SMBs to deliver higher bandwidth for congestion relief and smooth data delivery. Furthermore, 10GbE Gigabit uplinks to desktops also allow businesses to become highly efficient IT environments for secure, smooth daily online operations.
The ZyXEL GS1910 series consists of full-featured GbE Ethernet switch providing comprehensive Layer 2 switching capabilities such as Access Control List (ACL) rules, 802.1p Priority Queues per Port and 802.1AB LLDP and LLDP-MED, etc. The series delivers the essential network features for businesses with easy-to-use management at a right price. That is, the GS1910 series is the best edge switch range for small- and medium-size businesses to build high-performance network efficiently. -
When videos of higher resolution and data flow constantly evolve, network user demands might not be satisfied and business operations hampered by insufficient bandwidth. The ZyXEL GS1910 series provides GbE bandwidth to desktops to ensure sufficient bandwidth for all business communications, data delivery and daily operations. Taking advantages of GbE, businesses can create premium worry-free IT environment and expand operations with desirable efficiency and productivity. -
Energy management with IEEE 802.3az and IEEE 802.3at PoE Plus
As operating overheads such as electric bills increase constantly due to the rising green awareness, businesses have to avoid unnecessary energy waste. The built-in IEEE 802.3az Energy Efficient Ethernet (EEE) features of ZyXEL GS1910 series can reduce energy consumption of Ethernet devices through defining low-power modes and adjusting the operating timeframe to help saving the related costs effectively.
- Zyxel GS1910-24HP - switch - 24 ports - Managed
- Switch - 24 ports - Managed - stackable
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE) + 4 x shared SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 370 W
- Performance
- Switching capacity: 48 Gbps , Forwarding performance: 35.7 Mpps
- MAC Address Table Size
- 8K entries
- Remote Management Protocol
- RMON 1, RMON 2, SNMP, RMON 3, RMON 9, SNMP 3, HTTP
- Flow control, auto-negotiation, trunking, VLAN support, packet filtering, store and forward, MAC address filtering, IPv6 support, IP address filtering, half duplex mode, full duplex mode, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), IPv4 support, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), IP-MAC binding, SNMP trap, DHCP client, Management Information Base (MIB), 512KB packet buffer, loop prevention, port isolation, policy based access control
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, UPnP
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 35 cm x 4.4 cm
- 4.7 kg
- Localisation
- United Kingdom
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 370 W
- Performance
- 8K entries
- Max Units In A Stack
- 8
- Encryption Algorithm
- SSL
- Authentication Method
- RADIUS, TACACS+
- 24 x 1000Base-TX RJ-45 PoE , 4 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- 484 Watt
- MTBF
- 100,000 hours
- FCC, RoHS, BSMI CNS 13438, ICES, BSMI CNS 14336, LVD
- Localisation
- United Kingdom
- 44 cm
- 35 cm
- 4.4 cm
- 4.7 kg
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
