Prioritize Multimedia Streams for Optimized Video and Online Gaming Enjoyments
The ZyXEL GS-105S 5-Port Desktop Gigabit Ethernet Media Switch can easily connect multiple media devices to home networks at blazing-fast Gigabit speed simultaneously. Moreover, the newly designed QoS ports of GS-105S allow smooth video streaming and online gaming as well.
Plug-and-play, stylish design
With easy plug-and-play, you can connect the GS-105S to media players, game consoles and smart TVs to your home network without any configuration effort. With its stylish modern look and streamlined design, the GS-105S fits nicely into any home décor.
Smooth multimedia streaming and gaming
The ZyXEL GS-105S features QoS ports for you to assign high, medium or low priorities for your preferred network applications. For instance, if you are a movie enthusiast, you can connect media players or smart TVs to the high-priority ports for smooth video streaming and the best home 3D streaming experience. If you prefer lag-free online gaming, simply connect the game console through the high-priority QoS port and assign media players, PC and other network devices to the medium- or low-priority QoS ports according to your need.
Blazing-fast Gigabit speed
The GS-105S 10/100/1000 Mbps switch is designed for reliable high-performance media networks 10 times faster than Fast Ethernet connections. It perfectly fulfills the demands for multimedia streaming and online gaming.
Enlarge Plug-and-Play, stylish design
With easy Plug-and-Play, you can connect the GS-105S to media players, game consoles and smart TVs to your home network without any configuration effort. With its stylish modern look and streamlined design, the GS-105S fits nicely into any home decor. -
Enlarge smooth multimedia streaming and gaming
The ZyXEL GS-105S features QoS ports for you to assign high, medium or low priorities for your preferred network applications. For instance, if you are a movie enthusiast, you can connect media players or smart TVs to the high-priority ports for smooth video streaming and the best home 3D streaming experience. If you prefer lag-free online gaming, simply connect the game console through the high-priority QoS port and assign media players, PC and other network devices to the medium- or low-priority QoS ports according to your need. -
Enlarge blazing-fast Gigabit speed
- Zyxel GS-105S - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- Non-blocking switching capacity: 10 Gbps
- MAC Address Table Size
- 2K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP
- Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, Quality of Service (QoS), Energy Efficient Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V
- 10.6 cm x 7.5 cm x 3.2 cm
- 105 g
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- 2K entries
- 9KB
- Routing Protocol
- IGMPv2, IGMP
- Status Indicators
- Power, link/activity
- 1 x 1000Base-T RJ-45 high priority , 2 x 1000Base-T RJ-45 medium priority , 2 x 1000Base-T RJ-45 low priority
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 2.5 Watt
- Plug and Play, FCC Class B certified, C-Tick, BSMI, RoHS
- Localisation
- United Kingdom
- 10.6 cm
- 7.5 cm
- 3.2 cm
- 105 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
