The environment-aware switch 1100 series - Fast Ethernet offers 10/100M Ethernet speeds critical to the next-generation network applications, and it also provides power-saving functions to reduce energy consumption for lower operating cost.
The switch 1100 series - Fast Ethernet comprises of unmanaged Fast Ethernet switches that provide an inexpensive solution for Fast Ethernet connections to the desktop with outstanding performance. The switch 1100 series - Fast Ethernet is an ideal solution for bandwidth-intensive applications such as high-resolution photo delivery, video/audio streaming and downloading as well as server farm connections.
The full switch 1100 series has been designed to boost your network with better performance and efficiency. With the N-way auto-negotiation function, the switch 1100 series - Fast Ethernet connects the network counterparts with the highest possible data speed and activates the duplex mode automatically.
Unlike shared 10/100 Mbps networks, the switch 1100 series - Fast Ethernet eliminates congestion by providing dedicated bandwidth; and its duplex mode doubles the effective bandwidth by enabling two-way communications. The store-and-forward service brings low latency and error-free packet delivering, while the Plug-and-Play and multiple network protocol compatibility of the switch 1100 series - Fast Ethernet makes installation and management easier and faster than ever.
With embedded rackmount brackets, the desktop size devices can fits into your rack environment easily. No matter how intense your network demand is, the switch 1100 series - Fast Ethernet supports your needs with an affordable and reliable network solution designed especially for small businesses.
Best-in-class solution for Fast Ethernet environments
The switch 1100 series - Fast Ethernet comprises of unmanaged Fast Ethernet switches that provide an inexpensive solution for Fast Ethernet connections to the desktop with outstanding performance. The switch 1100 series - Fast Ethernet is an ideal solution for bandwidth-intensive applications such as high-resolution photo delivery, video/audio streaming and downloading as well as server farm connections. -
Better performance and efficiency
The full switch 1100 series has been designed to boost your network with better performance and efficiency. With the N-way auto-negotiation function, the switch 1100 series - Fast Ethernet connects the network counterparts with the highest possible data speed and activates the duplex mode automatically. -
Transmission reliability
Unlike shared 10/100 Mbps networks, the switch 1100 series - Fast Ethernet eliminates congestion by providing dedicated bandwidth; and its duplex mode doubles the effective bandwidth by enabling two-way communications. The store-and-forward service brings low latency and error-free packet delivering, while the Plug-and-Play and multiple network protocol compatibility of the switch 1100 series - Fast Ethernet makes installation and management easier and faster than ever. -
Desktop size with flexible rackmount and wallmount design fits your working environments
With embedded rackmount brackets, the desktop size devices can fits into your rack environment easily. No matter how intense your network demand is, the switch 1100 series - Fast Ethernet supports your needs with an affordable and reliable network solution designed especially for small businesses. -
Freedom of installation by PoE
The ES1100-16P supports IEEE 802.3af PoE to ease installation in challenging spaces such as ceiling or wall mounting. It works with devices such as WLAN APs, VoIP phones and IP surveillance cameras that can be powered by Ethernet connectivity over CAT-5 cables less than 100 meters (300 feet) in length; so there is no need for extra power adapters, and powering the devices installed on the ceiling is no longer a headache. This feature helps enterprises to reduce installation time and cost when many devices are needed.
- Zyxel ES-1100-16P - switch - 16 ports - unmanaged
- Switch - 16 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100 (PoE) + 8 x 10/100
- Power Over Ethernet (PoE)
- PoE
- Performance
- Switching capacity: 3.2 Gbps , Forwarding performance: 2.4 Mpps
- MAC Address Table Size
- 8K entries
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, Broadcast Storm Control
- IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x
- Power
- AC 120/230 V (50/60 Hz)
- 26.2 cm x 18.4 cm x 4.1 cm
- 1.7 kg
- Localisation
- United Kingdom
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Fast Ethernet
- Ports
- PoE
- Performance
- 8K entries
- RAM
- 160 KB
- Status Indicators
- Power, PoE, link/activity
- 8 x 100Base-TX RJ-45 PoE , 8 x 100Base-TX RJ-45
- Power Device
- Internal power supply
- Voltage Required
- RoHS, IEC 60950-1, EN 60950-1, FCC Part 15 A
- Localisation
- United Kingdom
- 26.2 cm
- 18.4 cm
- 4.1 cm
- 1.7 kg
- 0 °C
- 50 °C
- 10 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
