Zyxel ES-108A v2 8 port Desktop Fast Ethernet Switch, Metal Case
Quicklinx: 8Y7FWS00 Mfr#: ES-108AV2-GB0101F
Connect Multiple Devices with High Speed and Reliability
The ZyXEL ES-108A v2, a eight port desktop switch with plug-and-play design, can easily connect devices including PCs, network storage devices and print servers to your home network. The ES-108A v2 offers advanced High Priority ports to boost performance and user experience for Internet surfing, online gaming, multimedia or any application you prefer with prioritized bandwidth.
Compliant with the IEEE 802.3az Energy Efficient Ethernet standard, the ES-108A v2 provides power-saving benefits without compromising performance.
Easy to connect multiple devices
The ZyXEL ES-108A v2 is designed to boost your home network with better performance and efficiency. With the N-way auto-negotiation function, the ES-108A v2 connects to network devices with the highest possible speed and activates full-duplex mode automatically, while the store-and-forward service offers low latency and error-free packet delivery. The plug-and-play design allows you to easily connect devices such as PCs, network storage servers and print servers to the home network without manual configuration. To protect the network from broadcast storms, the ES-108A v2 can immediately locate a port experiencing loop errors and then blink the appropriate LED light.
Optimal bandwidth for media traffics through High Priority ports
The ZyXEL ES-108A v2 comes with three high priority ports. With the port-based QoS feature, the ES-108A v2 provides considerably enhanced download quality. Users can experience better performance for Internet surfing, online gaming and multimedia streaming through prioritized bandwidth settings. The ES-108A v2 features increased buffer memory to maintain smooth network transmission while the switch is handling heavy loads.
  • Compact and stylish design
    The stylish and compact metal housing of the ES-108A fits any working environments. The affordable and reliable series comes with 8 ports to meet home network expansion needs.
  • Get optimal bandwidth for media traffics through VIP ports
    The ZyXEL ES-108A is designed with 3 "VIP" ports. With port-based QoS feature, the ES-108A provides considerably enhanced download quality. Users can experience better performance of Internet surfing, online gaming and multimedia streaming preferred through prioritized bandwidth setting.
  • Easy to connect multiple devices
    The ES-108A is designed to boost your home network with better performance and efficiency. With N-way auto-negotiation function, the ES-108A connects to network counterparts with highest possible speed and activates full-duplex mode automatically, while the store-and-forward service brings low latency and error-free packet delivery. You can also easily connect devices such as PCs, network storages and print servers to the home network without any manual configuration.
  • Energy saving via link status and cable length detection
    The ES-108A features Green solutions that provide power-saving benefits without compromising performance. The ES-108A automatically reduces power usage by detecting any shutdown network device or inactive link. In other words, power consumption of the ES-108A adjusts usage according to the number of active network devices.
Zyxel ES-108A - v2 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Fast Ethernet
Ports
8 x 10/100
Performance
Switching fabric bandwidth: 1.6 Gbps
MAC Address Table Size
2K entries
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, Quality of Service (QoS), Energy Efficient Ethernet, 96KB packet buffer, loop prevention
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3az
15.45 cm x 8.5 cm x 2.6 cm
295 g
United Kingdom
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
8 x 10/100
Performance
2K entries
Status Indicators
Power, link/activity
3 x 100Base-TX RJ-45 high priority , 5 x 100Base-TX RJ-45
External power adapter
0.99 Watt
C-Tick, BSMI
United Kingdom
15.45 cm
8.5 cm
2.6 cm
295 g
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 95% (non-condensing)
