Zyxel 8-port GbE L2 PoE Smart Switch
Quicklinx: C1JGWS00 Mfr#: GS1900-8HP-GB0102F
The ZyXEL GS1900 Series of 8/10/16/24/48-port GbE Smart Managed Switch with Gigabit speed and essential managing functions bring your business network more flexibility and connectivity. The 1900 Series consists of nine (9) models—the GS1900-8, GS1900-8HP, GS1900-10HP, GS1900- 16, GS1900-24E, GS1900-24, GS1900-24HP, GS1900-48 and GS1900-48HP. Providing GbE switches with power-saving functions, fanless design and full IPv6 support ensure your network to be ready for future expansions. In addition, the PoE models GS1900-8HP/10HP/24HP/48HP Gigabit switch complies with the IEEE 802.3at Power over Ethernet (PoE) Plus standard. The complete GS1900 Series has been designed with useful features and advanced performances that empower your networks with speed and security as well as silent operation in your office environments.
The complete ZyXEL GS1900 Series has an essential portfolio of 8/10/16/24/48-port compact desktop and rackmount size with GbE connectivity. All models support multiple deployment methods to fulfill the needs for small offices and meeting room environments such as wall-, under table- or desktop-mounting and rackmount options1. It’s now quick and effortless to enjoy the high-speed business network applications without a hitch. Additionally, the GS1900-10HP/24/24HP/48/48HP is equipped with 2 extra SFP slots to provide 100M and GbE speeds for long-distance deployments.
The GS1900-8HP/10HP/24HP/48HP features IEEE 802.3at PoE Plus with up to 30 W powers per port to flexibly extend network deployment, especially for high-power devices such as Wi-Fi APs, IP cams and IP phones. The 802.3at PoE Plus capability makes the switch ideal for connecting numerous powered devices to form a flawless business network.
  • Versatility and flexibility for different needs
    The complete ZyXEL GS1900 series comes with compact size and GbE connectivity. It supports multiple deployment methods to fulfill the needs for small offices and meeting room environments such as wall-, under table- or desktop-mounting options. It's now quick and effortless to enjoy the high-speed business network applications without a hitch. The GS1900-8HP features IEEE 802.3at PoE Plus provide 8 PoE ports with up to 30 W powers per port to flexibly extend network deployment, especially for high-power devices such as Wi-Fi APs, IP cams and IP phones. The 802.3at PoE Plus capability makes the switch ideal for connecting numerous powered devices to form a flawless business network.
  • Simple, intuitive wizard set up
    For small businesses that want to manage their infrastructure in advance, the ZyXEL GS1900 series comes with a friendly built-in web-based browser for simple configuration and management. Moreover, the friendly step-by-step intuitive wizard helps avoiding multiple complicated configuration pages for quick set up with few clicks in the matter of minutes. To guide the users from start-up, VLAN, Guest VLAN to QoS setting, the complex steps have been combined into four quick individual steps; which does not just save deployment time and efforts, but is also helpful especially for the non-IT staff.
  • Avoiding network errors with easy management
    The ZyXEL GS1900 series is equipped with advanced management features to make the network stable and secure: loop protection that prevents network flooding, dual images to provide a backup FW if one crashes and storm control to ensure network efficiency, friendly on/off DoS with simple click to enable/disable instead of several setup pages, while SSL ensures the management frames are well encrypted when the device is accessed. The GS1900 series provides network error prevention features and integrated network security for reduced risk and improved data streaming.
  • Energy saving for IEEE 802.3az
    As operating overheads such as electric bills increase constantly due to the arising green awareness, businesses have to avoid unnecessary energy waste. The built-in IEEE 802.3az Energy Efficient Ethernet (EEE) and more ZyXEL green features of ZyXEL GS1900 series can reduce energy consumption of Ethernet devices through multiple intelligent ways.
  • Intelligence to power more devices
    ZyXEL's intelligent PoE feature provides two PoE supply modes: classification mode and consumption mode. Especially in consumption mode, the GS1900-8HP reserves the actual required power automatically, and you can set power feeding priorities on different ports to get the optimized use of power resource. This capability increases the number of devices connected and deliver a better ROI for the business. In addition, the GS1900-8HP supports the IEEE 802.3at standard on all 8 ports, providing a maximum of 30 watts per port, total 70 watts, for high power consuming devices.
Zyxel GS1900-8HP - switch - 8 ports - smart
Switch - 8 ports - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
70 W
Performance
Switching capacity: 16 Gbps , Forwarding performance: 11.9 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3
Flow control, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, WRR queuing, store and forward, IPv6 support, QoS, fanless, LACP support, LLDP support, Port Security, Energy Efficient Ethernet, MIB, SPQ, CoS, tagged VLAN, per port bandwidth control, 525KB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
25 cm x 10.4 cm x 2.7 cm
660 g
United Kingdom
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
70 W
Performance
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+
Status Indicators
Power, system, link/activity
8 x 1000Base-T RJ-45 PoE+ - 30 W
Internal power supply
90 watt
MTBF
533,086 hour(s)
FCC Class A certified, RoHS, EN 60950-1, BSMI CNS 13438, C-Tick Class A, BSMI CNS 14336
United Kingdom
25 cm
10.4 cm
2.7 cm
660 g
Limited warranty - lifetime
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
