Zalman Z9 Plus Tower Case with Fan Controller
Quicklinx: 8BR5WS00 Mfr#: Z9 PLUS
Z9 Plus supports bottom PSU installation and provides an aperture for cable management to make better use of interior space.
Front Mesh Cover for High Cooling Performance
The front mesh bay cover provides cool air into the system while dust filters prevent dust from entering.
Supports up to 7 System Fans
Up to 7 system fans are installed to expel hot air effectively from the case.
Supports Bottom PSU Installation and Aperture for Cable Management
Black Interior Coating
The interior of chassis is coated black to provide a sense of unity and elegant design.
Tool Free HDD Installation with Anti-Vibration Rubber
The server-type Tool-Free HDD Mount Trays allow easy HDD installation/removal and maintenance.
Spacious Interior for Installing 290mm Card
The interior has been designed to be spacious for easy installation and maintenance of various components.
Front I/O module for Easy Component Change
Front I/O module enables the location of DVD-ROM and other components to be changed easily according to user preference.
2-Channel Fan Controller and Temperature Display
2-Channel Fan controller for adjusting the system temperature and external LED temperature display are provided. By controlling noise and interior temperature with the fan speed, system can be operated at the most optimal condition.
Side Acryl Tuning
Side Acryl Tuning is provided for users to view the interior of gaming system.
Supports 4 USB 2.0
Front I/O module provides 4 USB 2.0 ports for user convenience and expandability.
Supports Front, Top, Side 120mm Blue LED fan and Rear 120mm Fan
Four 120mm fans deliver maximum cooling, and 3 Blue LED fan emphasizes cool aesthetics. For Z9, 1 front 120mm Blue LED and 1 rear 120mm White Impeller fan are provided.
Front and Bottom Dust Filters
Dust filters in the front and bottom mesh covers prevent dust from entering the system and keep the internal components dust-free.
Supports Solid State Drive (SSD)
Space is provided on the back of M/B plate for installing 2.5" HDD/SSD.
Separate Apertures for Convenient CPU Cooler Installation
Separate apertures for CPU cooler are provided for convenient CPU cooler installation without having to remove motherboard from case.
3IN1 Adapter Tray Provided
3IN1 Adapter Tray is provided for installing FDD / 3.5" HDD / 2.5" HDD/SSD.
Tube Apertures for Liquid Cooling Systems
Tube apertures are provided at the rear of the case for convenient water cooling set-up and maintenance.
In The Box
  • Main Unit
  • Stand-off
  • A Bolts (BH 6-32*6) [PSU/PCI Slot Installation]
  • B Bolts (PWH M3*5) [M/B, FDD, SSD Installation]
  • C Bolts (M3*6) [5.25" Bay ODD Installation]
  • D Bolts (#6-32*4) [3.5" Bay HDD Installation]
  • E-Bolts (#6-32*6) [3.5" HDD Installation]
  • HDD Anti Vibration Damper [3.5" Bay HDD Installation]
  • Cable Ties
  • CPU 12V Extension Cable
  • User's Manual
  • Enclosure Type ATX Mid Tower
  • Dimensions 207(W) x 464(H) x 504(D)mm
  • Weight 7.2kg
  • Material Plastic, Steel
  • Motherboard Compatibility Standard ATX / m-ATX
  • Power Supply Compatibility Standard ATX / ATX12V
  • VGA Compatibility Full Size (290mm)
  • Expansion Slot 7
  • Drive Bay External 5.25" 3
  • Internal 3.5" 5
  • External 3.5" 1
  • Internal 2.5" 1
  • Cooling Front 120mm /140mm fan x 1 (120? Blue LED fan x 1 standard)
  • Top 120? /140mm fan x 2 (120? Blue LED fan x 1 standard)
  • Bottom 120mm /140mm fan x 1 (option)
  • Rear (L) 120mm fan x 1 (standard)
  • Side 120mm fan x 2 (120mm Blue LED fan x 1 standard)
  • Front I/O Ports Mic x 1, Headphones x 1, USB 2.0 x 4, Fan Controller, Temperature Display
  • Color Black
  • Front mesh cover for high cooling performance
  • Supports up to 7 system fans
  • Supports bottom PSU installation and aperture for cable management
  • Black interior coating
  • Tool free HDD installation with anti-vibration rubber
    The server-type tool-free HDD mount trays allow easy HDD installation/removal and maintenance.
  • Spacious interior for installing 290 mm card
  • Front I/O module for easy component change
  • 2-channel fan controller and temperature display
    2-channel fan controller for adjusting the system temperature and external LED temperature display are provided. By controlling noise and interior temperature with the fan speed, system can be operated at the most optimal condition.
  • Side acryl tuning
    Side acryl tuning is provided for users to view the interior of gaming system.
  • Supports 4 USB 2.0
  • Supports front, top, side 120 mm blue LED fan and rear 120 mm Fan
    Four 120 mm fans deliver maximum cooling, and 3 blue LED fan emphasizes cool aesthetics.
  • Front and bottom dust filters
  • Supports Solid State Drive (SSD)
  • Separate apertures for convenient CPU cooler installation
  • 3in1 adapter tray provided
    3in1 adapter tray is provided for installing FDD/3.5" HDD/2.5" HDD/SSD.
  • Tube apertures for liquid cooling systems
Zalman Z9 Plus - tower - ATX
System cabinet
Tower
I/O Connectors
4 x USB 2.0 , 1 x audio line-out , 1 x microphone
Supported Motherboards
ATX, microATX
System Cabinet Features
Vibration-absorbing drive cage, screwless PCI card retainers, screwless drive bays, removable side panel, Water-Cooling Hole Ready, fan speed controller, meshed front panel, blue LED
No power supply (ATX12V)
20.7 cm x 50.4 cm x 46.4 cm
7.2 kg
Tower
Max Mainboard Size
ATX
ATX, microATX
Internal Bays Qty
6
Front Accessible Bays Qty
4
Cooling System
Front: 120/140 mm fan x 1 , Top: 120/140 mm fan x 2 , Rear: 120 mm fan x 1 , Side: 120 mm fan x 2
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x front accessible - 3.5" , 5 (total) / 5 (free) x internal - 3.5" , 1 (total) / 1 (free) x internal - 2.5"
Expansion Slots
7 x Expansion Slot
4 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
No power supply
Specification Compliance
ATX12V
20.7 cm
50.4 cm
46.4 cm
7.2 kg
