The Fractal Design Define S lends the appearance, sound dampening technology, and support for a wide variety of components from the widely popular Define Series, while introducing an innovative internal layout. The Define S case is packed with intelligently designed enthusiast-oriented features delivering a silent case with powerful and expansive air and liquid cooling support, presented in a stunning Scandinavian inspired construction.
The modernized internal layout of the Define S omits the optical drive bays, instead focusing on a clear straight airflow path and uncompromising water cooling support.
The Define S case reaches the highest level of silent computing through strategically placed dense sound-absorbing material, multiple ModuVent fan vent covers and finely tuned Dynamic Series fans.
- Fractal Design Define S - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Black
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Vibration damping, front dust filter, water cooling holes, ModuVent, cable management system, bottom dust filter, toolless design
- 23.3 cm x 52 cm x 45.1 cm
- 8.5 kg
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 5
- Black
- Cooling System
- Front: 140 mm fan x 1 / 1000 rpm , Rear: 140 mm fan mount x 1 / 1000 rpm , Front: 120/140 mm fan mount x 2 , Top: 120/140 mm fan mount x 3 , Bottom: 120/140 mm fan mount x 1
- CPU Cooler Max Height
- 180 mm
- Video Card Max Length
- 450 mm
- Expansion Bays
- 3 (total) / 3 (free) x internal - 2.5" / 3.5" shared , 2 (total) / 2 (free) x internal - 2.5"
- Expansion Slots
- 7
- 23.3 cm
- 52 cm
- 45.1 cm
- 8.5 kg
