Fractal Design Node 304 Computer Case (White)
Quicklinx: B56TWS00 Mfr#: FD-CA-NODE-304-WH
The Node 304 is the latest compact computer chassis from Fractal Design featuring a unique modular interior for outstanding configurability. The Node 304 accommodates up to six hard drives. Unused mounting brackets can removed to allow for long graphic cards, additional airflow or more space for organizing cables. Additionally, it is equipped with three hydraulic bearing fans, easy-to-clean air filters in all intakes and two front USB 3.0 ports.
Featuring hybrid functionality, the Node 304 case is ideally used as a cool-running file server, a stylish and quiet home theater PC or a powerful gaming system highlighting minimalistic and stunning Scandinavian design and maximum functionality.
Fractal Design Node 304 - tower - mini ITX
System cabinet
Tower
White
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
Mini-ITX, DTX
System Cabinet Features
Fan speed controller
No power supply (ATX)
25 cm x 37.4 cm x 21 cm
4.9 kg
Tower
Max Mainboard Size
Mini ITX
Mini-ITX, DTX
Internal Bays Qty
6
White
Cooling System
Front: 92 mm fan x 2 / 1300 rpm / removable and washable filter , Rear: 140 mm fan x 1 / 1000 rpm / removable and washable filter , Front: 80/92 mm fan mount x 2 , Rear: 120/140 mm fan mount x 1
Expansion Bays
6 (total) / 6 (free) x internal - 2.5" / 3.5" shared
Expansion Slots
2
No power supply
Specification Compliance
ATX
25 cm
37.4 cm
21 cm
4.9 kg
