The matte front door and side panels of the cabinet are equipped with noise absorbing materials for extreme silence. There are two pre-installed fans in the front and rear for optimized airflow, Moreover, the Cooler Master Silencio 452 provides liquid cooling ready for professionals and enthusiasts.
- Cooler Master Silencio 452 - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Midnight black
- Built-in Devices
- Card reader
- I/O Connectors
- 2 x USB 3.0 , 1 x USB 2.0 , 1 x microphone , 1 x audio line-out
- Supported Motherboards
- ATX, microATX
- System Cabinet Features
- Front panel door, removable HDD rack, front dust filter, supports 240 mm radiator in front panel, supports 120 mm radiator in rear, side panel sound-damping foam mats, bottom dust filter
- Power Device
- No power supply
- 19 cm x 49.7 cm x 44.9 cm
- 6.14 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- ATX, microATX
- Internal Bays Qty
- 8
- Front Accessible Bays Qty
- 2
- Supported Flash Memory Cards
- SD Memory Card
- Built-in Devices
- Card reader
- Midnight black
- Cooling System
- Front: 120 mm fan x 1 / 800 rpm / 2 x 120/140 mm fan supported , Rear: 120 mm fan x 1 / 800 rpm / 1 x 80/90 mm fan supported
- CPU Cooler Max Height
- 158 mm
- Video Card Max Length
- 386 mm
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 3.5" , 2 (total) / 2 (free) x front accessible - 2.5"
- Expansion Slots
- 7
- 2 x USB 3.0 , 1 x USB 2.0 , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack
- Power Device
- No power supply
- 19 cm
- 49.7 cm
- 44.9 cm
- 6.14 kg
- Limited warranty - 2 years
