Be Quiet Silent Base 600 Gaming Case ATX No PSU Tool-less - Black
Quicklinx: BQ8RWS00 Mfr#: BG006
Case Form Factor: Tower
Motherboard Form Factor: ATX
Colour: Black
£90.89 ex VAT
£109.06 inc VAT
Unique Performance and Usability
be quiet! Silent Base 600 offers the perfect symbiosis of noise prevention and cooling performance, a good usability and an extensive capacity for high-end hardware.
Highlights
  • Outstanding performance thanks to an innovative construction that assures excellent cooling efficiency and a perfect air-circulation at well-known whisper-quiet operation
  • Excellent usability with simplest mounting and tool-free fitting of drives, an intelligent and adaptable cable solution, and air intake filters that are easily accessed for cleaning
  • Ample space and cutouts are provided for high-end components of today and tomorrow, including space for water cooling radiators
  • Two pre-installed Pure Wings 2 fans feature nine airflow-optimized fan blades and are decoupled from the case to circulate air with a minimum of vibration and the quietest possible operation; 3-step fan controller included
  • Side panel with adjustable vent that can be closed for silent operation, partially open for increased air intake or open with an additional fan for higher cooling performance
  • Professional cable management is supported with generous space for organizing cables, silicone rubber grommets, and carefully placed pass-throughs
  • Product conception, design and quality control in Germany
  • 3-years manufacturer’s warranty
Silent Base 600
The design team’s mission was based on the principle "form follows function", and so every last detail in the Silent Base 600’s design has a functional purpose. It is truly a superior case ideal for high-end gaming gear and quiet systems.
be quiet! Silent Base 600 - tower - ATX
System cabinet
Tower
I/O Connectors
2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Noise reduction, vibration-absorbing drive cage, manual fan speed control, side panel dust filter, removable dust filter, vibration damping, front dust filter, CPU cut-out, bottom mounted PSU holder, cable management system, removable HDD cage, bottom dust filter, airflow channels, tool-less drive bays, Liquid Cooling Ready, vented side panel
No power supply
23 cm x 49.5 cm x 49.3 cm
7.84 kg
3-year warranty
Tower
Max Mainboard Size
ATX
Internal Bays Qty
6
Front Accessible Bays Qty
3
Cooling System
Front: 140 x 140 x 25 mm fan x 1 / 900 rpm / 55.8 cfm / 17.1 dBA / Pure Wing 2 , Rear: 120 x 120 x 25 mm fan x 1 / 1200 rpm / 41.7 cfm / 16.8 dBA / Pure Wing 2 , Top: 120/140 mm fan mount x 2 , Bottom: 120/140 mm fan mount x 1 , Side: 120 mm fan mount x 1 , Front: 140 mm fan mount x 1
CPU Cooler Max Height
167 mm
Video Card Max Length
413 mm
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 3 (total) / 3 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5"
Expansion Slots
7
2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
Accessory box
RoHS
No power supply
23 cm
49.5 cm
49.3 cm
7.84 kg
Limited warranty - 3 years
Colour: Black
Brand: Be Quiet
