The WPL406 industrial barcode printer features a low profile, industrial design at an affordable price; and delivers the reliability your organization can depend on. Featuring an all-metal exterior housing and die-cast aluminum print mechanism, the WPL406 can withstand even the harshest of conditions. Print speed of up to 6 inches per second at 203 dpi resolution is supported by 8 MB of SDRAM, and 4 MB of Flash memory, making the WPL406 ideal for high volume print applications. The WPL406 industrial barcode printer includes a LCD display, with 6-button control panel for easy installation and use. The WPL406 is also RoHS compliant.
- Wasp WPL406 - label printer - B/W - direct thermal / thermal transfer
- Printer Type
- Label printer - direct thermal / thermal transfer - B/W
- 11 kg
- Max Media Size
- Roll (11.8 cm)
- Min Media Size (Custom)
- 25 mm
- Max Media Size (Custom)
- 118 mm
- Print Speed
- Up to 152 mm/sec
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB, LAN, serial
- RAM Installed (Max)
- 8 MB SDRAM
- Flash Memory Installed (Max)
- 4 MB
- Language Simulation
- ZPL, EPL, WPL
- Barcodes
- Code 93, Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Code 128B, Code 128C, Code 128A
- Media Type
- Labels
- Peeler
- Networking
- Print server
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows 2000/XP/Vista/7/8
- 2-year warranty
- 28.6 cm x 43.4 cm x 25.9 cm
- Printer Type
- Label printer - direct thermal / thermal transfer - monochrome
Printer
- Print Speed
- Up to 152 mm/sec - 203 dpi
- Built-in Devices
- Status LCD, peeler
- Connectivity Technology
- Wired
- Interface
- USB, LAN, serial
- 203 dpi
- ZPL, EPL, WPL
- Peeler
- Barcodes
RAM
- 8 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 4 MB
Media Handling
- Media Type
- Labels
- Max Media Size
- Roll (11.8 cm)
- 25 mm
- 118 mm
- Media Sizes
- Roll (11.8 cm)
- Max Printing Width
- 106 mm
- Max Printing Length
- 2286 mm
- Roll Maximum Outer Diameter
- 208 mm
- Roll Core Diameter
- 76.2 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (11.8 cm)
- Networking
- Print server
- Connections
- 1 x serial , 1 x USB , 1 x LAN
- Cables Included
- 1 x USB cable
- Consumables Included
- 1 x ribbon
- FCC Class A certified, UL, TUV, cUL, CCC, C-Tick Class A
- OS Required
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 28.6 cm
- 43.4 cm
- 25.9 cm
- 11 kg
