WASP WHC25 Desktop Wristband Printer
Quicklinx: GB88WS00 Mfr#: 633808525156
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: Roll (5.2 cm)
£268.30 ex VAT
£321.96 inc VAT
The Wasp WHC25 direct thermal wristband printer is designed to meet the needs for healthcare patient identification, hospitality, and event ticketing applications. Using direct thermal print technology, the WHC25 eliminates the need to purchase toner and ribbons, making it an easy-to-use, cost effective solution when compared to a laser printer. When printing wristbands with text, graphics, and barcodes the thermally embedded ink will not bleed or get ruined should it become damp.
Wasp WHC25 Desktop Wristband Printer - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1.2 kg
Max Media Size
Roll (5.2 cm)
Min Media Size (Custom)
15 mm
Max Media Size (Custom)
52 mm
Max Resolution (B&W)
203 dpi
USB, LAN
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB
Card Reader
Language Simulation
ZPL, EPL, WPL
Barcodes
Code 93, Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, China Post, Code 128B, Code 128C, Code 128A
Fonts
9 fonts
Styles & Effects
Rotated text
Print server
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
10.9 cm x 26 cm x 21 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Built-in Devices
Status LCD
Wired
USB, LAN
203 dpi
Language Simulation
ZPL, EPL, WPL
Fonts
9 fonts
Styles & Effects
Rotated text
Fonts Included
8 x bitmapped , 1 x scalable
Barcodes
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Media Handling
Max Media Size
Roll (5.2 cm)
15 mm
52 mm
Max Printing Width
52 mm
Max Printing Length
2286 mm
Roll Maximum Outer Diameter
16.5 cm
Roll Core Diameter
25.4 mm, 38.1 mm
Print server
1 x USB 2.0 , 1 x LAN - RJ-45
1 x USB cable
Wall mountable
FCC Class B certified, TUV, cUL, C-Tick Class B, CCC
Power supply - internal
5 °C
10.9 cm
26 cm
21 cm
1.2 kg
Type: Printer
Brand: WASP
