WASP WPL618 Industrial Barcode Printer, 18 IPS, 203 DPI
Quicklinx: GB81WS00 Mfr#: 633809003486
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: Roll (11.4 cm)
£1,896.28 ex VAT
£2,275.53 inc VAT
The WPL618 industrial barcode printer is both versatile and easy to use with features like direct thermal and thermal transfer printing, 6-button color LCD resistive touch screen for fast configuration, and enhanced print quality.
Wasp WPL618 - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
18 kg
Max Media Size
Roll (11.4 cm)
Max Media Size (Custom)
115 mm
Print Speed
Up to 457 mm/sec
Max Resolution (B&W)
203 dpi
USB 2.0, LAN, serial, USB host
RAM Installed (Max)
512 MB SDRAM
Flash Memory Installed (Max)
512 MB
Language Simulation
ZPL, ZPL II, EPL, WPL
Barcodes
Code 93, Code 39, GS1 DataBar, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, Data Matrix, China Post, Plessey, Code 128B, Code 128C, Code 128A, EAN-128, EAN-8, EAN-13, MSI, RSS
Media Type
Labels, continuous forms, fanfold paper, die cut labels
Black Mark sensor, gap sensor, ribbon end sensor, ribbon encode sensor, open head sensor
Total Media Capacity
1 roll
30 cm x 51 cm x 39.3 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
Printer
Print Speed
Up to 457 mm/sec - 203 dpi
Built-in Devices
4.3 inch LCD touch screen
Wired
203 dpi
Language Simulation
Barcodes
RAM
RAM Installed (Max)
512 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
512 MB
Media Handling
Media Type
Max Media Size
Roll (11.4 cm)
115 mm
Media Sizes
Roll (11.4 cm)
Max Printing Width
104 mm
Max Printing Length
25400 mm
Media Thickness Range
0.076 mm - 0.305 mm
Roll Core Diameter
76.2 mm
1 roll
Media Feeders
1 x manual - 1 roll - Roll (11.4 cm)
1 x USB 2.0 , 1 x RS-232 , USB host - 4 pin USB Type A , 1 x LAN - RJ-45
1 x USB cable
FCC Class B certified, UL, TUV, cUL, CB, C-Tick Class B, CCC, RoHS, WEEE, EAC, BIS
Power supply - internal
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
5 °C
25 - 85% (non-condensing)
30 cm
51 cm
39.3 cm
18 kg
Type: Printer
Brand: WASP
Price Range Ex VAT: £1500+
