WASP WPL206 Desktop Barcode Printer (Direct Thermal Labels only)
Quicklinx: GB7TWS00 Mfr#: 633809003462
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: Roll (11.4 cm)
£277.28 ex VAT
£332.73 inc VAT
The Wasp WPL206 desktop barcode printer has the perfect balance between price, performance and durability. It features a double wall clamshell design, direct thermal printing, 5 inches per second printing speed at a 203 DPI resolution and plenty of memory: 64 MB Flash memory and 128 MB SDRAM to produce high quality printed labels, even at its fastest print speeds.
The Wasp WPL206 desktop barcode direct thermal printer is ideal for healthcare, retail, warehouse and logistics, entertainment and hospitality environments.
Wasp WPL206 - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1.3 kg
Max Media Size
Roll (11.4 cm)
Max Media Size (Custom)
114 mm
Print Speed
Up to 127 mm/sec
Max Resolution (B&W)
203 dpi
USB 2.0
RAM Installed (Max)
64 MB SDRAM
Flash Memory Installed (Max)
128 MB
Language Simulation
ZPL, ZPL II, EPL, WPL
Barcodes
Code 93, Code 39, GS1 DataBar, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, MicroPDF417, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, Data Matrix, China Post, Plessey, Code 128B, Code 128C, Code 128A, EAN-128, EAN-8, EAN-13, MSI, RSS
Media Type
Labels, continuous forms, fanfold paper
Black Mark sensor, gap sensor, open head sensor
Total Media Capacity
1 roll
17.2 cm x 19.5 cm x 16.5 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Up to 127 mm/sec - 203 dpi
Wired
USB 2.0
203 dpi
Language Simulation
Barcodes
RAM
RAM Installed (Max)
64 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
128 MB
Media Handling
Media Type
Max Media Size
Roll (11.4 cm)
114 mm
Media Sizes
Roll (11.4 cm)
Max Printing Width
108 mm
Max Printing Length
2286 mm
Media Thickness Range
0.055 mm - 0.19 mm
Roll Core Diameter
25.4 mm, 38 mm
1 roll
Media Feeders
1 x manual - 1 roll - Roll (11.4 cm)
1 x USB 2.0
1 x USB cable
FCC Class A certified, CB, CCC, RoHS, WEEE, C-Tick Class A
Power adapter - external
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
5 °C
25 - 85% (non-condensing)
17.2 cm
19.5 cm
16.5 cm
1.3 kg
Type: Printer
Brand: WASP
