TP LINK AV1000 Powerline Starter Kit
Quicklinx: FTN9WS00 Mfr#: TL-PA717 KIT
TTL-PA7020P KIT, an adapter, with its practical design and sophisticated power-saving mode, will automatically switch from its regular "Working" mode to "Power-Saving" mode reducing its energy consumption by up to 85%. Comes with advanced HomePlug AV2 technology, TL-PA7020P KIT provides users with high-speed data transfer rates of up to 1000Mbps, which is ideal for bandwidth intensive applications such as multiple HD/3D/4K video streaming, online gaming and large file transfers. With 2 gigabit Ethernet ports, TL-PA7020P KIT can simultaneously connect up to 2 wired-only devices. This makes the TL-PA7020P KIT the perfect home entertainment companion. Connect any 2 devices from smart TVs and games consoles to NAS boxes and computers to the Internet at the same time. Just plug the Ethernet cable into the powerline and away you go. Connect a powerline adapter to the router; plug another powerline adapter into a wall socket in another room, and connect it to your Internet enabled device via Ethernet - and you're done. Where sockets are at a premium, the TL-PA7020P KIT with an integrated AC pass-through power socket, means the powerlines can be used like a traditional electrical socket. Plug your smart TV or games consoles into the powerlines, as if it were a normal plug socket. No socket needs to go to waste. The built-in noise filter helps to prevent electrical signal noise from affecting powerline performance.
  • Flawless streaming
    With advanced technology, TL-PA717 KIT provides high-speed data transfer rates, ideal for bandwidth-intensive applications such as multiple HD video streams, cloud gaming, and large file transfers.
  • Gigabit port for maximum connectivity
    With one Gigabit Ethernet port, TL-PA717 KIT allows you to connect a bandwidth-intensive device to the Internet at high speeds, ensuring smooth video streaming.
  • No configuration required
    Connect a powerline adapter to the router, then plug another powerline adapter into a wall socket in another room. Finally, connect it to your Internet-enabled device via Ethernet - and you're done.
TP-Link AV1000 - Starter Kit - powerline adapter kit - wall-pluggable
Powerline adapter kit
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0
Data Transfer Rate
1 Gbps
Reset button, pair button
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0
AC 220 V (50 Hz)
5.2 cm x 2.85 cm x 6.5 cm
Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 2003, Windows 8, Windows 8.1
United Kingdom
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1 Gbps
Max Range Indoors
300 m
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0, Plug and Play, RoHS
Status Indicators
Power, LAN
Line Properties
Line Coding Format
OFDM
LAN: 1 x Ethernet 1000
Internal power supply
AC 220 V (50 Hz)
2.7 Watt
1 x network cable - 2 m
United Kingdom
5.2 cm
2.85 cm
6.5 cm
10 - 90% (non-condensing)
