TP LINK AV2000 2 Port Gigabit Powerline Starter Kit
Quicklinx: F9DWWS00 Mfr#: TL-PA9020PKIT
Type: Powerline adapter kit
Speed: 2000Mbps
Connectivity: Wired
Pass-through Socket: Yes
£78.45 ex VAT
£94.14 inc VAT
With advanced HomePlug AV2 MIMO, the TL-PA9020p delivers high speed of up to 2000Mbps over powerline to provide superior network performance that supports all of your online needs. With a lag-free connection, you will never miss out again.
The TL-PA9020P creates fast, high performance wired connections that support all of your favorite devices, like 4K HDTV. Now you can plug in to enjoy an exclusive fast lane out of a crowded network without slowing down.
  • Take your powerline network to the next level
  • An exclusive fast lane for your favorite devices
  • Fluid streaming and gaming with 2X2 MIMO
    2X2 MIMO with Beamforming technology significantly improves speeds, especially during peak hours.
  • More stable connections
    2X2 MIMO is like adding extra lanes to a highway. It establishes multiple simultaneous connection for you to enjoy higher speeds and greater stability.
  • Enhanced long distance performance
    2X2 MIMO with Beamforming technology also offers the benefit of improved coverage throughout the home, particularly for previously hard to reach outlets.
  • Wiring up with Gigabit speeds
    Connect to Gigabit speeds for your smart TVs, game consoles, computers and network attached storage devices. Just use an Ethernet cable to attach your devices to the powerline adapter to get started!
  • No power outlet is going to waste
    The integrated power socket means that you can still get power from the outlet for your other devices. Simply plug your device into the integrated socket the same way you would with a normal wall outlet. The built-in noise filter also helps to eliminate electrical signal noise that might otherwise affect powerline transmission performance.
TP-Link Powerline TL-PA9020P KIT - Starter Kit - powerline adapter kit - wall-pluggable
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0, IEEE 1901
Data Transfer Rate
2000 Mbps
QoS
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
7.2 cm x 4.2 cm x 13.1 cm
Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows 2003, Microsoft Windows Vista / XP / 7 / 8
Australia
Packaged Quantity
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
2000 Mbps
Encryption Algorithm
128-bit AES
QoS
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, Plug and Play, RoHS
Status Indicators
Power, LAN
Line Properties
Line Coding Format
OFDM
LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV 2.0
Internal power supply
5.8 watt
2 x network cable - 2 m
Australia
7.2 cm
4.2 cm
13.1 cm
10 - 90% (non-condensing)
Speed: 2000Mbps
Connectivity: Wired
Brand: TP LINK
