TP LINK AV1300 Gigabit Powerline Starter Kit
Quicklinx: F9DSWS00 Mfr#: TL-PA8010P KIT V2
Type: Powerline adapter kit
Speed: 1.3Gbps
Connectivity: Wired
Pass-through Socket: Yes
Hurry, only 1 left in stock!
£54.17 ex VAT
£65.00 inc VAT
Using your home's existing electrical circuit, TP-LINK's TL-PA8010P KIT AV1200 Gigabit Passthrough Powerline Starter Kit turns any electrical socket into an Internet connection. Simply plug into your wall socket and you are ready to enjoy HD streaming and gaming, no configuration required. You also won't lose a socket with its integrated pass through socket included! With speeds of 1200 Mbps for smooth Ultra HD streaming, online gaming or faster downloads, TL-PA8010P KIT is a perfect home entertainment companion.
  • 1200 Mbps, perfect for bandwidth demanding activities
    With its advanced HomePlug AV2 technology, TL-PA8010P KIT is introducing a powerline generation for even faster data transmission in the home network. TL-PA8010P KIT supports 2 x 2 MIMO with beamforming, so users benefit from ultra-fast data transfer speeds of 1200 Mbps. Perfect for bandwidth demanding activities like streaming ultra HD video to multiple devices simultaneously, online gaming and large file transfers.
  • Gigabit Ethernet port for HD video streaming
    Equipped with one gigabit Ethernet port, TL-PA8010P KIT allows users to connect a bandwidth intensive device in a room and ensures the smooth transmission of multiple HD video streaming.
  • Extra power socket for additional devices
    Where sockets are at a premium, the TL-PA8010P KIT with an integrated AC pass-through power socket, means the powerlines can be used like a traditional electrical socket. Plug your smart TV or games consoles into the powerlines, as if it were a normal plug socket. No socket needs to go to waste. The built-in noise filter helps to prevent electrical signal noise from affecting powerline performance.
TP-Link TL-PA8010P KIT - v2 - Starter Kit - powerline adapter kit - wall-pluggable
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0, IEEE 1901
Data Transfer Rate
1.3 Gbps
2T2R MIMO technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0, IEEE 1901
AC 220 V (50 Hz)
13.1 cm x 7.1 cm x 4.2 cm
Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7/8/8.1/10
United Kingdom
Packaged Quantity
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1.3 Gbps
Max Range Indoors
300 m
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0, IEEE 1901, Plug and Play, RoHS
Status Indicators
Power, link/activity
Line Properties
Line Coding Format
OFDM
1 x HomePlug AV 2.0 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
AC 220 V (50 Hz)
4.9 Watt
1 x network cable - 2 m
United Kingdom
Software Included
Drivers & Utilities
13.1 cm
7.1 cm
4.2 cm
10 - 90% (non-condensing)
Speed: 1.3Gbps
Connectivity: Wired
Brand: TP LINK
