TP LINK RE365 AC1200 Wi-Fi Range Extender
Quicklinx: FT7XWS00 Mfr#: RE365
Type: Wi-Fi range extender
Speed: 1.2Gbps
Connectivity: Wired, Wireless
Pass-through Socket: No
  • IEEE 802.11n
£39.01 ex VAT
£46.81 inc VAT
The AC1200 Wi-Fi Range Extender connects to your router wirelessly, strengthening and expanding its signal into areas it can't reach on its own, achieving speeds of 300Mbps on the 2.4GHz band and 867Mbps on the 5GHz band.
  • Intuitive Web UI
    Ensures quick and simple installation without hassle.
  • Fast encryption
    One-touch wireless security encryption with the WPS button
  • LED On/Off
    Conveniently turn on or off LEDs as required.
  • Power On/Off
    Conveniently power on or off your extender as required.
  • Hassle-free management with Tether App
    Network management is made easy with the TP-Link Tether App, available on any Android or iOS device.
  • Ultimate wireless speed
    Wireless speeds of up to 300Mbps on the 2.4GHz band and 867Mbps on the 5GHz band.
  • Support 802.11 AC
    Provides a data transfer rate 3 times faster than 802.11n for each stream.
  • Fast Ethernet port
    Acts as a wireless adapter to connect wired devices.
  • Simultaneous dual band
    Separate Wi-Fi bands enable more devices to connect to your network without a drop in performance.
  • Reliable connection
    Two adjustable antennas for optimal Wi-Fi coverage and reliable wireless connections.
  • Universal compatibility
    Works with any Wi-Fi router.
TP-Link RE365 - Wi-Fi range extender - Wi-Fi 5
External
France
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8.1 / 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8
7 cm x 7.7 cm x 12.5 cm
3-year warranty
7 cm
7.7 cm
12.5 cm
France
External
Wireless, wired
Data Transfer Rate
1.2 Gbps
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Rating
AC1200
Status Indicators
Access Point operational mode, Wi-Fi Protected Setup (WPS), reset button
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Aerial
Antenna Qty
2
1 x 1000Base-T - RJ-45
FCC, RoHS
Internal power supply
8 watt
Limited warranty - 3 years
Speed: 1.2Gbps
Connectivity: Wired
Connectivity: Wireless
Brand: TP LINK
