TP LINK AV1000 2-Port Gigabit Passthrough Powerline Starter Kit
Quicklinx: FZ67WS00 Mfr#: TL-PA7027PKIT
Integrating advanced HomePlug AV2 technology, this kit provides users with high-speed data transfer rates up to 1000 Mbps, which is ideal for bandwidth-intensive applications such as simultaneous HD/3D/4K video streaming, online gaming, and large file transfers. Just plug in and enjoy!
  • Extend an AV1000 speed network to any outlet
  • Two Gigabit ports for high-speed connections
    Provide reliable high-speed wired connections for game consoles, smart TVs, STBs, and more.
  • Don't worry about occupying an outlet
    Simply plug into your TL-PA7027P KIT as though it were a normal wall socket. Feel free to plug in PCs, smart TVs, or other wired appliances without any performance differences. The built-in noise filter helps prevent electrical signal noise from affecting your powerline performance.
  • Up to 85% power saved
    The future's looking green for powerline adapters. TL-PA7027P KIT's practical design and sophisticated Power-Saving Mode, which automatically switches from its regular "Working" mode to "Power-Saving" mode, reduce its energy consumption by up to 85%.
TP-Link TL-PA7027P V1 Starter Kit - powerline adapter kit - wall-pluggable
Powerline adapter kit
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0, IEEE 1901
Data Transfer Rate
1000 Mbps
Power-saving mode, pair button
IEEE 802.3, IEEE 802.3u, HomePlug AV, HomePlug AV 2.0, IEEE 1901
5.8 cm x 4.2 cm x 9.5 cm
320 g
Apple MacOS, Linux, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
3-year warranty
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1000 Mbps
Max Range Indoors
300 m
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, HomePlug AV, HomePlug AV 2.0, IEEE 1901, Plug and Play
Built-in Devices
Power outlet
Status Indicators
Power, Internet, powerline
Line Properties
Line Coding Format
OFDM
2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV 2.0
Internal power supply
4 Watt
2 x network cable
5.8 cm
4.2 cm
9.5 cm
320 g
3-year warranty
10 - 90% (non-condensing)
