This Thunderbolt 3 PCIe expansion chassis lets you add a PCI Express card to your laptop or desktop computer, through an external Thunderbolt 3 connection. The chassis also features a DisplayPort video output, so you can connect an additional monitor to your laptop, and supports Thunderbolt 3 daisy chaining, so you can expand your workstation even further.
Expand the capabilities of your Thunderbolt 3 computer
The Thunderbolt 3 PCIe chassis makes it easy to expand your system with the capabilities you need to work at peak productivity. You can add many types of PCI Express cards, such as a PCIe USB 3.1/3.0/2.0 and USB-C, SSD, network, eSATA, FireWire or video capture cards. And, with the speed and bandwidth support of Thunderbolt 3 and PCIe 3.0, you can enjoy many of the same port additions you would from the PCI Express expansion slots of a desktop system. -
Extend your workstation
The external PCIe enclosure features a dedicated DisplayPort output that lets you add an additional display to your laptop or desktop computer. The enclosure features a second Thunderbolt 3 (USB-C) port, that you can use to connect a secondary display (a USB-C video adapter may be required). With multiple extended displays, you can work more efficiently by multitasking faster, and avoid the hassle of continually repositioning several open windows or programs. You can also use the second Thunderbolt 3 port to connect additional Thunderbolt, USB and DisplayPort devices to your system. You can daisy chain up to six Thunderbolt 3 devices and expand your workstation to suit your specific requirements. -
Increase productivity with faster speeds
Thunderbolt 3 is the fastest connection available, which means you don't have to deal with the performance bottlenecks of a slower connection, and can accomplish more in the same amount of time. At up to 40Gbps this Thunderbolt 3 expansion chassis gives you the throughput to add displays to your laptop, access files quickly, and work without disruptions. It's easy to access and edit large uncompressed files such as videos and images on the fly, making it ideal for dynamic on-site production. The TB31PCIEX16 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com Thunderbolt 3 PCIe Expansion Chassis, External Enclosure Box with 1x PCI-Express Slot, 5K/4K Output Via TB3/DP Ports, TAA - system bus extender - DP
- Product Type
- System bus extender
- Video Interfaces
- DP
- 27.3 cm x 8.2 cm x 14 cm
- 1 kg
- Black
- Power
- Power adapter AC 100/240 V (50/60 Hz) 65 Watt Power Provided
- 2-year warranty
- Designed For
- P/N: TB3DK2DPM2, TB3DOCK2DPPD, TB3DOCK2DPPU
- Product Type
- 27.3 cm
- 8.2 cm
- 14 cm
- 1 kg
- Enclosure Colour
- Black
- Expansion Slots
- 1 (total) / 1 (free) x PCI Express 3.0 x16 (x4 mode)
- 2 x Thunderbolt 3 - 24 pin USB-C , 1 x display / video - DisplayPort - 20 pin DisplayPort
- Cables Included
- 1 x Thunderbolt cable - external
- Included Accessories
- 4 x rubber feet
- LED indicator, built-in cooling fan
- FCC, RoHS, WEEE
- Power Device
- Power adapter
- Voltage Required
- AC 100/240 V (50/60 Hz)
- Power Provided
- 65 Watt
- OS Required
- Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 2 years
- 5 °C
- 35 °C
- Designed For
StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter | In Stock | £49.12 |
StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length | In Stock | £327.11 |
StarTech.com PCI Express X1 to X16 Low Profile Slot Extension Adapter | In Stock | £19.72 |
StarTech.com PCI Express to 4 Slot PCI Expansion System | In Stock | £376.57 |
StarTech.com 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485 | In Stock | £110.54 |
StarTech.com 4 Port PCIe USB 3.0 Card | In Stock | £23.79 |
StarTech.com USB-C to VGA Adapter | In Stock | £22.16 |
StarTech.com 4-Port Gigabit NIC - PCIe | In Stock | £151.83 |
StarTech.com 2-Port 10G Fiber NIC-Open SFP+ | In Stock | £295.64 |
StarTech.com 2x M.2 SSD Controller - PCIe | In Stock | £21.26 |
StarTech.com USB-C to HDMI Adapter | In Stock | £15.52 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £18.76 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £22.59 |
StarTech.com U.2 to PCIe Adapter -SFF-8639 | In Stock | £27.51 |
StarTech.com Thunderbolt 3 PCIe Enclosure | In Stock | £233.89 |
StarTech.com 4x M.2 PCIe to TB3 Enclosure | In Stock | £308.81 |
StarTech.com Thunderbolt 3 PCIe External | In Stock | £467.33 |
