StarTech.com Thunderbolt 3 PCIe Enclosure
Quicklinx: D4FGWS00 Mfr#: TB31PCIEX16
Device Type: Desktop Computer, Laptop
Type: System bus extender
Device Screen Size: [N/A]
Colour: Black
26 In Stock
£233.89 ex VAT
£280.66 inc VAT
This Thunderbolt 3 PCIe expansion chassis lets you add a PCI Express card to your laptop or desktop computer, through an external Thunderbolt 3 connection. The chassis also features a DisplayPort video output, so you can connect an additional monitor to your laptop, and supports Thunderbolt 3 daisy chaining, so you can expand your workstation even further.
  • Expand the capabilities of your Thunderbolt 3 computer
    The Thunderbolt 3 PCIe chassis makes it easy to expand your system with the capabilities you need to work at peak productivity. You can add many types of PCI Express cards, such as a PCIe USB 3.1/3.0/2.0 and USB-C, SSD, network, eSATA, FireWire or video capture cards. And, with the speed and bandwidth support of Thunderbolt 3 and PCIe 3.0, you can enjoy many of the same port additions you would from the PCI Express expansion slots of a desktop system.
  • Extend your workstation
    The external PCIe enclosure features a dedicated DisplayPort output that lets you add an additional display to your laptop or desktop computer. The enclosure features a second Thunderbolt 3 (USB-C) port, that you can use to connect a secondary display (a USB-C video adapter may be required). With multiple extended displays, you can work more efficiently by multitasking faster, and avoid the hassle of continually repositioning several open windows or programs. You can also use the second Thunderbolt 3 port to connect additional Thunderbolt, USB and DisplayPort devices to your system. You can daisy chain up to six Thunderbolt 3 devices and expand your workstation to suit your specific requirements.
  • Increase productivity with faster speeds
    Thunderbolt 3 is the fastest connection available, which means you don't have to deal with the performance bottlenecks of a slower connection, and can accomplish more in the same amount of time. At up to 40Gbps this Thunderbolt 3 expansion chassis gives you the throughput to add displays to your laptop, access files quickly, and work without disruptions. It's easy to access and edit large uncompressed files such as videos and images on the fly, making it ideal for dynamic on-site production. The TB31PCIEX16 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Startech Thunderbolt 3 PCIe Expansion Chassis, External Enclosure Box with 1x PCI-Express Slot, 5K/4K Output Via TB3/DP Ports, TAA - system bus extender - DP
System bus extender
Video Interfaces
DP
27.3 cm x 8.2 cm x 14 cm
1 kg
Power adapter AC 100/240 V (50/60 Hz) 65 Watt Power Provided
P/N: TB3DK2DPM2, TB3DOCK2DPPD, TB3DOCK2DPPU
System bus extender
27.3 cm
8.2 cm
14 cm
1 kg
Enclosure Colour
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x16 (x4 mode)
2 x Thunderbolt 3 - 24 pin USB-C , 1 x display / video - DisplayPort - 20 pin DisplayPort
1 x Thunderbolt cable - external
4 x rubber feet
LED indicator, built-in cooling fan
FCC, RoHS, WEEE
Power adapter
Power Provided
65 Watt
Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
5 °C
35 °C
D4FG StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter In Stock £49.12
D4FG StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length In Stock £327.11
D4FG StarTech.com PCI Express X1 to X16 Low Profile Slot Extension Adapter In Stock £19.72
D4FG StarTech.com PCI Express to 4 Slot PCI Expansion System In Stock £376.57
D4FG StarTech.com 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485 In Stock £110.54
D4FG StarTech.com 4 Port PCIe USB 3.0 Card In Stock £23.79
D4FG StarTech.com 4-Port Gigabit NIC - PCIe In Stock £151.83
D4FG StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £295.64
D4FG StarTech.com 2x M.2 SSD Controller - PCIe In Stock £21.26
D4FG StarTech.com USB-C to HDMI Adapter In Stock £15.52
D4FG StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.76
D4FG StarTech.com USB-C to DisplayPort Adapter In Stock £22.59
D4FG StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £27.51
D4FG StarTech.com Thunderbolt 3 PCIe Enclosure In Stock £233.89
D4FG StarTech.com 4x M.2 PCIe to TB3 Enclosure In Stock £308.81
D4FG StarTech.com Thunderbolt 3 PCIe External In Stock £467.33
Device Type: Laptop
Colour: Black
