StarTech.com 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485
Quicklinx: 8GTPWS00 Mfr#: PEX4S232485
Type: Serial adapter
Compatibility: PC
Interface: PCI Express x1
£115.47 ex VAT
£138.56 inc VAT
Add two RS232, and two RS422/485 serial ports to your PC through a PCI-Express expansion slot. The PEX4S232485 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485 lets you add two RS232, and two RS422/485 serial ports to your PC through a PCI-Express expansion slot.
This PCI express serial card is a single card solution that is compatible with nearly any serial communication protocol, supporting RS-232, RS-422, RS-485 2-wire or RS-485 4-wire operating modes.
A flexible solution for adding serial ports to full-sized, or small form factor systems, the 4-port serial card includes both low and full profile brackets while the included breakout cable helps to avoid cluttered connections.
  • Secure connectivity
    This card features wired technology, ensuring stable and secure connections for various devices requiring serial communication. The combination of RS-232 and RS-422/485 interfaces expands applicability across multiple devices.
  • Robust operating range
    Designed to function optimally between 0°C and 100°C, this card handles a wide range of environmental conditions, making it dependable for diverse settings without compromising performance.
  • Standard compliance
    The StarTech.com 4 Port PCI Express PCIe Serial Combo Card adheres to FCC and RoHS standards, ensuring it meets safety regulations and environmental guidelines, making it a trustworthy solution for professionals.
StarTech.com 4 Port PCI Express PCIe Serial Combo Card - serial adapter - PCIe - 4 ports
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
2 cm x 7 cm x 12.5 cm
67.4 g
Ports Qty
4 ports
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
Serial adapter - 4 ports
Plug-in card
PCI Express x1
Wired
2 x RS-232 - 9 pin D-Sub (DB-9) (on cable) , 2 x RS-422/485 - 9 pin D-Sub (DB-9) (on cable)
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC, RoHS
2 cm
7 cm
12.5 cm
67.4 g
Limited warranty - lifetime
100 °C
20 - 80%
8GTP StarTech.com 2 Port USB to RS232 RS422 RS485 Serial Adapter with COM Retention In Stock £82.78
8GTP StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD In Stock £159.61
8GTP StarTech.com 1-Prt PCI Express Serial Card In Stock £38.02
8GTP StarTech.com PCIe Dual Serial Port Card In Stock £44.95
8GTP StarTech.com 2-Port Serial PCIe Card In Stock £66.56
Compatibility: PC
